Clutch Delete Supercharger Pulley! No more Heavy Back plates!
Old Apr 18, 2020 | 11:55 AM
  #51
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
Old Apr 18, 2020 | 12:10 PM
  #52
SICAMG's Avatar
2005 e55 AMG
I would think than running a fixed pulley and than say a UPD torque converter that is 10lb's lighter would make a very big difference. I know first hand that a lighter converter makes a huge difference on engine response. Taking drag away from the blower is doing the same thing.
To bad I can not run the fixed in how I race. I need to have that clutch off when waiting to run.
Old May 20, 2020 | 01:36 PM
  #53
SPONSOR
E55 C63
68mm Will be back in stock in a few weeks!
Old May 20, 2020 | 01:37 PM
  #54
BC928's Avatar
2006 E55, Various other German and ‘Murican
Can you respond to me on my issue? I have demonstrated the dimensions are incorrect.
Old May 20, 2020 | 02:21 PM
  #55
SPONSOR
E55 C63
Just responded via email
Old May 20, 2020 | 03:28 PM
  #56
eurochargedw210's Avatar
w210 E55
what
what do y’all do about heat soak, with the fixed pulley?
Old May 20, 2020 | 03:36 PM
  #57
SPONSOR
E55 C63
It all depends on your Cooling modifications.
Old Jul 12, 2020 | 02:40 PM
  #58
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
Couple of questions. I would really appreciate it if anyone running this setup can give some input. I have 2 m113k cars. want to play with pulley and tune on at lease one of them. both car have heat exchanger upgrade, split cooling and 010 pumps.
1. How is the tune working out for the Clutch delete pulley? I read other post that fixed pulley have hesitation in the tune. Has this been worked out? Im asking because as great as the pulleys are. If the tune isnt working well it is rather useless.
2. How are you guys putting up with the supercharger rattle & whine? it is tolerable? or annoying in anyway?
Thanks for your input.
Old Jul 12, 2020 | 02:57 PM
  #59
w210 E55
Dont waste your time. We have the fastest e55 in the world, doesn’t have a fixed pulley. We have the highest power e55 with factory blower, doesn’t have a fixed pulley. You want issues, get a fixed pulley.
Old Jul 12, 2020 | 03:04 PM
  #60
w210 E55
Also have someone explain and prove any of the advantages of a fixed pulley?
Old Jul 13, 2020 | 08:48 AM
  #61
new55's Avatar
04 55
no clutch explosion would be one advantage, boost at 800 rpm would be two,,, as far as speed goes probably no difference but screwing around town i think would be more fun as response/boost is immediate
Old Jul 13, 2020 | 09:24 AM
  #62
w210 E55
I’ve never seen a pulley explode, in working on Mercedes for the last 10 years. Fixed pulley, heat heat heat heat heat. Yes I seen some bearings go out. You know the clutch locks up pretty instantly right?
Old Jul 13, 2020 | 03:07 PM
  #63
coupesedan's Avatar
CLS55
Early versions of the UPD 83 can turn into sawzalls. Sometimes the springs fail on the original pulley too
Old Jul 13, 2020 | 11:28 PM
  #64
MSG 55G's Avatar
Veteran: Army
2006 E55
Good thing I didn’t see my clutched pulley explode...was pulling pulley out to exchange for a fixed. Needless to say I escaped a catastrophe. 😯
Old Jul 16, 2020 | 06:17 PM
  #65
fkong777's Avatar
I also found a pulley failure. The dog bone rivet started to stretch out the hole. This was a 76mm pulley that came with one of my M113k cars. the clutch disk started to become off center. I went back to a stock pulley.after.
Old Jul 16, 2020 | 06:50 PM
  #66
tw2's Avatar
tw2
I just run a scatter shield and hope for the best. Regular checking helps too.
Old Jul 17, 2020 | 05:45 PM
  #67
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
Yea same here
Old Oct 8, 2020 | 05:27 PM
  #68
SPONSOR
E55 C63
All sizes in stock!
Old Dec 7, 2020 | 03:29 PM
  #69
SPONSOR
E55 C63
Use code MBWORLD2020 for an exclusive discount!
>> shop this pulley! <<
Old Dec 7, 2020 | 03:33 PM
  #70
BC928's Avatar
Can you send mine? After, what, nearly a year? Don’t email me. Just send it.
Old Dec 7, 2020 | 06:30 PM
  #71
SICAMG's Avatar
2005 e55 AMG
That's big ***** for them to sell them like this and you still have not gotten yours...or a correct one. Your a patient man Brendan !!
Old Dec 7, 2020 | 07:00 PM
  #72
SPONSOR
E55 C63
Edit: Found the order. leaving today.
Old Jan 4, 2021 | 12:35 PM
  #73
SPONSOR
E55 C63
Old Jan 4, 2021 | 02:16 PM
  #74
ctravis595's Avatar
2002 CL500 to CL55 conversion
Originally Posted by SICAMG
That's big ***** for them to sell them like this and you still have not gotten yours...or a correct one. Your a patient man Brenden !!
ditto
you guys are aware of what these superchargers sound like with a fixed pulley, correct? Sounds like marbles in a tin can, not very Mercedes-like at all
Old Jan 4, 2021 | 03:04 PM
  #75
w210 E55
Originally Posted by ctravis595
ditto
Also last time I checked, all of the fastest 113k cars run clutched pulleys. Fixed pulleys are trash!
Let’s see VRP post some air intake temps, and some actual date on why to even use a fixed pulley.
