W211 E55 coilover conversion journey
Old Feb 27, 2018 | 08:02 PM
Hotsauce55's Avatar
2005 E55
This will be over the next month or two. Plugging away a bit here and there. Starting phases today, removed air compressor and started on the electrical connectors and links.
The connector's to the shock and to the linkage are off. Where do they connect, run and what have you guys done with them?
Do I pull both connectors from the top shock tower remove the wiring or just leave?
Old Feb 27, 2018 | 10:43 PM
tw2's Avatar
tw2
Sorry I can't help but I thought I would mention there is a YouTube video of a guy doing the install and ripping out the airmatic in his carpark. Might pay to have a look if you haven't seen it already. I think he ended up just taping the electrical connectors out of the way.
Old Feb 28, 2018 | 06:42 AM
Hotsauce55's Avatar
2005 E55
Watched a few on YouTube. Didn't see anyone completely strip the electrical wiring out. I suppose I can cut out the airlines and remove the distribution block completely?
Old Feb 28, 2018 | 01:46 PM
tw2's Avatar
tw2
I think he removed all the air lines but not the wires. I don't think you will save much weight on the wiring and a lot of it will be very hard to access. The hardlines pump and air springs are where the bulk of the weight will be.
Old Feb 28, 2018 | 03:04 PM
Hotsauce55's Avatar
2005 E55
Access is an issue for sure, I'm more concerned with cleanliness than weight savings. I'll just tape em off & remove as many of the air lines as possible.
Old Mar 3, 2018 | 10:47 AM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
I removed everything related to the Arimatic from mine, including the centre console rising/lowering button.
Old Mar 3, 2018 | 03:42 PM
Hotsauce55's Avatar
2005 E55
You spend the time unwrapping wiring harness to do it? Was it a pita?
Old Mar 3, 2018 | 05:06 PM
tw2's Avatar
tw2
Did you replace the button with a blanked off piece from a non-airmatic w211? Was it difficult?
Old Mar 4, 2018 | 11:53 AM
Alex L's Avatar
Wiring harness, air lines... Fiddly but not impossible to do. Depends on what you're used to I suppose lol.
Yes, I used a blanking button. Not difficult but you have to lift the trim and undo two screws from underneath to swap it out. Looks much cleaner too:
View this post on Instagram
Old Mar 5, 2018 | 06:22 AM
Hotsauce55's Avatar
2005 E55
Can the BC racing coilover's get the car high enough to keep my alignment in check?
Old Apr 9, 2018 | 12:15 PM
Hotsauce55's Avatar
2005 E55
Started this up, things have been slow with renovations of entire home.
Procedure for removal of fronts:
- pull wheel off
- remove wheel well liner and bolts, requires some force getting that out
- remove connectors top shock, level sensor and shock itself
- cut air lines if you're done forever with airmatic
- tape up all connectors to indicate they are related to airmatic
- remove lower control arm bolt 21mm
- remove 3 upper ballpoint bolts T45
- remove 3 shock tower bolts 13mm
- remove shock
- remove level sensor
fronts are really little trouble
Old Apr 9, 2018 | 12:18 PM
Hotsauce55's Avatar
2005 E55
I'm into the rear now. Removing the airmatic LCA. 2 questions:
1. Do I need to remove the brake caliper and if so how do I make sure it doesn't eat my fingers?
2. To remove the bolt connecting the LCA to the spindle it appears to be a 21mm on the back side and some other massive 6 point male socket. Anyone know the size?
Old Apr 9, 2018 | 02:26 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
All of your questions answered in this thread:
https://mbworld.org/forums/e-class-w...sion-help.html
Old Apr 21, 2018 | 07:15 AM
Hotsauce55's Avatar
2005 E55
Assuming this threaded length never gets adjusted?
Old Apr 21, 2018 | 07:19 AM
Hotsauce55's Avatar
2005 E55
Coilovers were well packaged and received reasonably quickly from order payment date via a US warehouse.
Customer service sucks with BC which is apparently no surprise. Twice I had asked a rep to get back to me to discuss custom rates but never heard back so went with standard rates.
Old Apr 22, 2018 | 11:04 AM
Hotsauce55's Avatar
2005 E55
Got my 12pt and Allen keys for the rear
in terms of setting preload can I do that with coilovers already installed?
Old Apr 22, 2018 | 06:15 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Install everything. It helps if others can give you starting measurements; i.e. number of turns or inches/mm from the bottom of the threaded sleeve to the bottom of the spring perch.
You want a half-tank of fuel and the equivalent driver's weight in the driver's seat (170 pounds of cement in plastic bags in my case). Then corner weight to get the diagonals as close as possible. Remember, when you raise the spring perch, you put more pressure (weight) on that wheel, lower the perch, you put less pressure (weight) on that wheel. Again, you want the diagonals to be as close as possible. If you have the LF to RR combined weight of 2,100 pounds, and the RF to LR is 2,125 pounds, you're good. I always aimed for +/- 10 pounds difference on the old turbo Miata but it only weighed 2190 pounds empty (with >260 rwhp). On the Mercedes, I would allow a bit more leeway. Perform an internet search on corner weighting and read to your heart's content. Rather than purchasing the scales (expensive), it would be worthwhile for you to just take it to a shop that can perform corner weighting one time and leave it at that. Be advised if you decide to change ride height later, I would again recommend corner weight verification.
FWIW, Flyin' Miata (FM) out of Colorado has some great stuff for corner weighting but it is aimed at lower weight vehicles (like 2400 pound Miatas with 530 horsepower Corvette engines installed). Our 4,200 pound E55's are above the recommended load-bearing capacity of FM's offerings. :-(
Old Apr 22, 2018 | 06:44 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
Just in case you didn't get it answered, if you just unplug the large plug on the SBC module you are good to pull the callipers off. Easy to access and not tricky to unclip or anything. I would opt for a 1/2" drive hex head socket instead of an allen key. All of the bolts on mine were super hard to break. Maybe you will have better luck than me but I don't think I would have been able to break that one suspension bolt with an allen.
Old Apr 22, 2018 | 08:23 PM
Hotsauce55's Avatar
2005 E55
Thanks guys, I will dig into this more nearing the end of the week. For the fronts I have exactly 5 inches between the bottom and top collars.
in terms of setting height you unlock the bottom collar and adjust. Unlocking the top collars plays with preload, coreect?
also looks like removing the inner most rear lca bolt ie. 12 pt triple square that the exhaust has to come down unless I get the short version of the bit?
Old Apr 22, 2018 | 10:13 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Everything I used (Ground Control) used a fixed upper and adjustable lower. So...I would hypothesize use lower spring perch to set height and, if adjustable upper perch(?), use that to adjust preload. Again, I repeat, again, use corner weighting. Read. Read. Read. Study. Learn.
Old Apr 22, 2018 | 10:23 PM
Hotsauce55's Avatar
2005 E55
Thanks and no need to repeat yourself, I hear ya & it’s helpful. Let me get the coilovers on the car first
Old Apr 22, 2018 | 11:58 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
I can't say about the inner LCA bolt and the exhaust sorry. I took mine apart to put in a LSD so I had the exhaust off already and left the LCA hanging by the inner bolt so I never touched it.
Old Apr 23, 2018 | 10:38 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
LOL! My apologies. I was close to finishing off a bottle of very good red wine about that time and got a little verbose.
Looking at photos from the time I worked on the rear suspension it appears I did have to lower the exhaust. I just unbolted the brackets under the rear bumper, the brackets just in front of the rear axles. and removed the center tie bar between the exhaust pipes and let the exhaust just hang.
Old Apr 23, 2018 | 12:14 PM
Hotsauce55's Avatar
2005 E55
Thumbs up
All good, you are an immense help to the community, who doesn't get a little chatty when the booze is flowing anyways
I might look at the shorter triple square bits to avoid the incremental labour of the exhaust
Old Apr 24, 2018 | 07:59 PM
Hotsauce55's Avatar
2005 E55
Man this job is grinding down my love for the car lol
need an e18 female torx now to remove the calliper and swing up so I can access the 12mm hex and get the impact on it. Not budging otherwise
then get the inner most rear lca bolt out 12mm 12 pt and I can’t get bolt out because of exhaust. So gotta drop that now too.
