E55 255 up front ???
Old Mar 7, 2018 | 09:32 AM
alenpepic's Avatar
2005 CL55 (sold) C63 Coupe 2012 p31(sold) Audi 330awhp E55 511WHP(sold)Z06C6 550whp C63 LTH
I got a 8.5 front rim with a 32 offset I'm slapping 5mm spacers so it should be a 27 offset for a 255. I'm thinking about getting federal rsrr and they only have 245 in a 35 tire profile. Problem is those tires are more like a 255. From what I know about this car my setup should be far away from the brake so maybe I can run that tire Bc I know a lot of guys had issues with bigger tires Bc the offset was to high
Old Mar 7, 2018 | 10:24 AM
hayseed's Avatar
04 e55
I always get this mixed up but if your adding a spacer you are pushing the wheel farther out from zero/center hub and adding offset unless the offset of the wheel is really a negative number -- and I think it depends on the wheel manufacture if its a positive or negative number -- I have 255/40 on 8.5 with an oem 25 offset and seem to work fine - maybe someone can straighten me out
Old Mar 7, 2018 | 02:17 PM
alenpepic's Avatar
spacer makes the offset lower
Old Mar 8, 2018 | 04:25 AM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
I run a 255 tyre on 8.5J +30. No issues.
