03 e55 amg driveshaft spins when in gear, wheels dont
Old Mar 7, 2018 | 03:11 PM
Kyle Harris's Avatar
2003 AMG E55
can anyone tell me whats going on? it makes a grinding sound also. heres a video of it...
https://youtu.be/CVEDdNGGIR4
Old Mar 7, 2018 | 03:18 PM
BoostedAero's Avatar
2004 E55
roasted rear diff, need to replace
Old Mar 7, 2018 | 03:26 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Yep, that rear is done.
Old Mar 7, 2018 | 04:28 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
You need a whole new rear end, hopefully the differential housing isn't damaged. And can be reused, but the pinion bearing, ring gear and differential is toast.
And this is going to be an expensive repair. Sorry....
Old Mar 7, 2018 | 06:19 PM
SICAMG's Avatar
2005 e55 AMG
If only the spider gears broke you may get away with just that... proly not though. They are {rear diffs} very easy to work on and you can have it out in a couple hours if you are mechanical. Same with the axles if broken.
Also I have a rear diff for later E55's but the axles are different. Something you can work with let me know. If needed I will send it to you.
Good Luck
Old Mar 7, 2018 | 06:37 PM
tw2's Avatar
tw2
Time for a quaife.
