Service brake error.
I have searched.... This issue is so confusing.
I am getting an intermittent "service brake" error. Maybe once a week. I have had it three times now. I only get the warning in white, not red. I do not get an esp light with it and my brake lights work normally when I have the error (probably not a brake switch). When I start the car back up it is gone. It is usually appearing mid drive and appears to have no rhyme or reason when it appears.
From reading in some places there is a brake wear message. Is this correct? I see diagnoses for this issue as check pad wear and the sensor but it seems to be a different warning light. My pads are new and am unsure about the sensors, however if the sensors had issue wouldn't I see a "brake wear" message?
I know I should go have a shop run STAR on it to properly diagnose it. I don't want to pay close to 200 after tax to find out just now if I don't have to. Any suggestions would be greatly appreciated.
Yes, the fault code will be stored in the SBC control unit for quite a while. You need to check the codes. It could be several things, but the most likely is probably the brake light switch. When they start failing, they're often very intermittent, so it would only happen once in a while and the switch would most likely be working fine when you check the brake lights.
