2006 E55. ABS light on, ESP & ABS malfunction
I was driving to work and all of a sudden the car starts lighting up everything on the dash (similar to when a car starts up), the speedo drops to 0 and up to 40mph a few times, and the transmission doesn't shift for a while (probably a thousand feet) and it goes back to normal with ABS, ESC malfunction showing, ABS light on the dash, and heavy steering. I drive the car back home after work with the same symptoms and it sits for a week or so before I can attempt to figure out what is wrong/fix it.
A week or so later, I run my diagnostic tool (Autel Maxisys MS906) on the vehicle and the fault code points to a front left wheel sensor. I look up how to change it, seems pretty easy, and order the part (a Febi Bilstein). Another week passes and in the meantime I have had to take the car out a few times and a new message has now popped up with the ABS, ESC malfunction: adaptive head lighting something unavailable (I'm going to guess that it is probably due to the ABS speed sensor.)
So last night, I changed the front left ABS sensor using this
Today, I lifted the car again to make sure the connection to the steering knuckle was good. As this is the first time I am using my diag tool, I decided to take the car out and see the live data (which I will attach below) and it definitely is still the front left ABS speed sensor issue but I noticed a weird number with the "Steering Angle Sensor." Like I previously mentioned, this is my first time using this diag tool so I am not sure if this would be a separate issue or would be related....I'm starting to believe it is...On the live data, it does change when I move the wheel, however it the range is wayyyy off.
Also, I am not sure if this is related but the first time I had my car on jacks /lifted the car, a few minutes after the car was on the stands, water started coming out from a drain hole on the front right bottom on the car...(which scared the **** out of me). Still the same thing, so I took the car to the dealer, and they tell me it is due to the aftermarket sensor...which I think is total BS...I take the car back, $150 dollars lighter...I have done some research and searching, and some threads point toward: reluctor ring, wheel bearing, or the ESP module......
This is where I am stuck at ATM. My next move will probably be to take out the front right ABS sensor and stick it back in to see if I did everything correctly on the left side and to check the harness. Any ideas, comments, tips, anything would be helpful. I have also sent back the Autel scanner and currently waiting for one of those Chinese clones to come...
Attached are pictures from my diag.
I will definitely switch out front sensors and check the resistance on the SBC. Will post back on Sunday when I can wrench on the car.
Any thoughts on the steering angle??
To clarify: measuring at the SBC unit is just to measure both wires and the sensor in one shot (you're still measuring the sensor not the internal resistance of the SBC unit).
Regarding the steering angle... Was your wheel straight ahead at the time or turned?
So with the steering angle.....when the steering wheel is leveled (meaning the wheels are straight) the SAS reads 0 on the live data. In the picture, the wheel is turned to the left which gives a big negative number. If I remember correctly, doing a sharp turn, changes the value of the SAS to close to -300 to 300 depending on which direction I turn.
Would the correct procedure be to figure out the sensor issue first, see if it is corrected, then tackle the SAS? or could the SAS throw the ABS sensor off?
The only reason that I mentioned the SAS being off is because the scanner I used has the range for the values at -2.5 through +2.5. Thought something was off. I guess I am chalking that up to scanner software issue. Got a STAR clone on the way though!
Thanks again brother.
