Billet Oil cooler Fittings - For Aftermarket oil cooler or factory line replacement
Old Apr 17, 2018 | 09:45 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
1 Piece oil cooler adapter fittings
These adapt the M113 Oil cooler to -10AN for replacing leaky factory Lines or adding an aftermarket oil cooler
$95 Per pair.
http://vrpspeed.com/index.php?route=...product_id=399
SPONSOR
E55 C63
Old Apr 17, 2018 | 11:01 PM
mbmg's Avatar
2004 E55
Those would work well with these -10an male custom to stock oil cooler fittings. Just add braided -10an hose. . You can instead use an aftermarket oil cooler as Phil suggested or weld male -10an fittings to the stock oil cooler.
Old Apr 17, 2018 | 11:10 PM
tlambert's Avatar
2005 E55 AMG
The oil cooler adapter fittings are cool. But $95 pair. Wow.
Old Apr 17, 2018 | 11:49 PM
mbmg's Avatar
2004 E55
The price isn't bad for custom pieces considering the cost of a replacement hose assembly of about $316 - $450 (2115000275) and the hassle to reroute factory lines.
Old Apr 18, 2018 | 12:47 AM
knowbenz's Avatar
Benz
Thats a fair price imo.
Old Apr 18, 2018 | 11:58 AM
SPONSOR
E55 C63
$95 for the first pair, if you add another set the second set is $85, Third set is $75
Old Apr 18, 2018 | 01:28 PM
Punisher10mm's Avatar
2003 E55
Who sells these fittings?
Old Apr 18, 2018 | 01:34 PM
mbmg's Avatar
2004 E55
No one sells them from my research which is why they are custom made. I can make more if there is enough interest.
Old Aug 24, 2018 | 07:50 AM
SPONSOR
E55 C63
Old Jan 5, 2019 | 03:53 PM
wpbmed's Avatar
E55AMG, Lexus ES350, Lexus LS460, AudiA6
Are these so you can delete the stock thin oil cooler which hangs below the super charger heat exchanger and add an aftermarket oil cooler instead? thanks
Old Jan 5, 2019 | 09:44 PM
wpbmed's Avatar
Can anyone tell me the correct oil flow direction? Small cooler on the bottom of heat exchanger, larger cooler with fan attached, then back to the engine? Or larger cooler with fan attached, smaller cooler on bottom of heat exchanger, then back to the engine?
thank you.
Old Jan 11, 2019 | 11:18 AM
EVOII_Racer's Avatar
Mercedes Evo II
Sorry wrong thread please delete my Post sorry
Old Jan 11, 2019 | 01:06 PM
turabaka's Avatar
2004 E55 AMG
I'm curious what the difference is between these fittings, and the ones that Yoshifab offers?
Or are they literally the same thing?
https://yoshifab.com/store/mercedes-...tting-set.html
Old May 5, 2019 | 12:41 AM
MercWyo's Avatar
W211 E55 AMG
It seems like the connection to the secondary oil cooler doesn't have a good solution, but I am confused a bit here.
I understand the AN10 fittings with the O-rings and then AN10 lines down to the lower oil cooler. However, the connections at the 'secondary oil cooler'(2115000400) appear to need some special kind of 'custom' fitting as noted below. I am assuming based on the offer to custom fabricate the M22x1.5 threaded male connector that there is no standard readily available option?
Factory secondary oil cooler fitting:
Old May 5, 2019 | 12:56 AM
mbmg's Avatar
2004 E55
Correct, at that time the M22x1.5 threaded male connector adapters aren't readily available unless Phil or someone else is now fabricating them. Those were one-off prototypes.
Old Dec 24, 2019 | 01:46 PM
Sportunage's Avatar
2005 W215 CL55 AMG
Did you ever gain enough interest to produce a batch of these? I’m in need of a set.
Old Dec 24, 2019 | 01:59 PM
mbmg's Avatar
2004 E55
PM sent
Old Sep 24, 2020 | 05:01 PM
KeremP's Avatar
SL55
Originally Posted by VictoryRoadPerformance
What size are those bolts that attach to the fittings? I have the stock lines but one of my bolts disappeared and I couldn't find the right size.
Old Dec 7, 2020 | 03:54 PM
SPONSOR
E55 C63
Use code MBWORLD2020 at checkout for an exclusive discount!
>> shop here! <<
Old Jul 15, 2022 | 10:17 AM
Jak423's Avatar
2004 E55 AMG, 2011 Porsche Cayenne Turbo
Any chance you’re still making these?
Old Jul 15, 2022 | 10:47 AM
mbmg's Avatar
2004 E55
No, I only made a set of prototypes. Although these would make the conversion easier, Phil's suggestions above would cost less.
Old Oct 28, 2023 | 07:17 PM
WISETECH's Avatar
E55 & ML55
https://www.vrpspeed.com/product/oil...or-10-fitting/
Is this the oil cooler adapter needed to replace cooler hoses? I took off the lines and noticed the oil cooler had a flared fitting.
Old Oct 28, 2023 | 10:01 PM
mbmg's Avatar
2004 E55
Yes, those are just like the ones that I made. They will adapt the oil cooler to a -10an fitting (hose end).
Old Jul 16, 2025 | 04:50 PM
kttolai's Avatar
2003 s55 amg
hi do u sell the oil cooler fittings to 10an? I need them asap if you do
