Possible transmission failure? Help
I just hit 100K and my tranny is making a wierd whining noise. The tranny started slipping as well and locks itself in whatever gear its in. When i restart the car. It seems to catch the gear and run fine for a second. But the whining noise will continue and it will start to slip and lock itself in a gear again. Im super frustrated at this point and even my indy mechanic is certain its the tranny and doesnt even want to look into it. I cant even check the fluid level and i feel at a complete loss as to what to do right now. If i really need a new tranny at this low of miles i might have to Leave MB forever, i just had the conductor plate done and a tranny service done 30K miles ago. Anyone run into this problem? And is it true if i need a new tranny i have to take it to the dealer for it to get coded? I love this car very much but after 7K spent on maintence i dont know if i can spend another 2-3K on a used tranny.
That sucks, don't feel too bad though, I'm at $9,800 over last 40k miles doing the work myself
Given you're in so deep whats another $2K especially for a transmission, you won't get jack **** for car without a working one.
2005 E55 AMG, 1991 MR2
Coding is only needed on E63 TCU/conductor plate replacement. I can't see are you in a E63 or 55? I know your pain. I rebuilt my CLK transmission at the dealer. Then I decided I couldn't stand the car after so many problems. And here I am...
Get a STAR read out. That can usually pin point what is happening. Along with fluid level and a basic external inspection you should have all the info you need.
Received 1,490 Likes
This place is a joke.
Step 1) Check the fluid level. You'll need the MB dipstick tool to do this.
Step 2) If fluid level is correct- drop the pan and look for metal fragments.
The whining noise MAY be your front pump failing inside the transmission.
thanks for the reply, i think i found a good transmission guy i can trust. Is it normal for a car to just start slipping? No prior signs of any tranny issues. I know alot of the times people will lose a gear and it just continues to get worse after that. I just took the car for a drive and got the noise and slipping
It has to start at some point. Usually the first occasions would be when you are hitting it hard. I was going up a hill at WOT 100mph when I first got limp mode and a code for impossible gear ratio. Then it was fine driving around town for a few weeks, then it occasionally started doing it then too until almost once per trip. Mine was worn clutch packs, you may have other issues.
[QUOTE=gsean430;7445940]
thanks for the reply, i think i found a good transmission guy i can trust. Is it normal for a car to just start slipping? No prior signs of any tranny issues. I know alot of the times people will lose a gear and it just continues to get worse after that. I just took the car for a drive and got the noise and slipping[/QUO
Guy's don't understand that these transmissions will "compensate" for worn clutch's all the time.....until it gets to the point where it is past the point of no return.
Then problems will arise. They are easy to rebuild so an independent builder shouldn't hit yo to hard with price.
