Differentials: Sourcing HAG215 Housing
Had an emergency come up (try and guess what could've possibly happened...), would like to know what other cars had a compatible housing.
I know 2005-2009 W211 cars had the new housing, but are there others that had the HAG215?
I know I'll need to upgrade the axles as well.
Trying to put a proper LSD in.
SL55 has the same diff as the pre-August ‘03 E55. R230 SL63 N/A has later type with bigger shafts and ring gear.
Later diffs fit early cars as you said. Have to buy the single piece shafts. Hub spline are the same in early and later E55.
I know 2005-2009 W211 don't cars had the right housing, but are there others?
