Halp, Mysterious overheating problem
Old Jun 1, 2018 | 04:38 AM
Mr.F's Avatar
09 E63
09 E63, at the start of the summer I noticed that after my 1.25 hour commute that the rad fan would be blowing at full speed and delayed in shutting off after that car is turned off. Further investigation showed engine oil, trans oil and coolant all running at about 115c. Further inspection showed the water pump was leaking from the weep hole under the pulley, no other leaks present. It was replaced, along with the thermostat. Vacuum filled with distilled water at first for a drive around the block then drained and refilled with 50/50 zerex g-05. Didn't seem to have had any effect on the temperatures. The level in the reservoir is steady, no coolant going anywhere. Everything steadily climbs up to 105c, then slowly creeps up to 115c regardless of my speed, heater being turned on, engine rpm, etc. The fan works, the t-stat is doing what it should do, you can feel both hoses heat up, as well as the radiator completely come up to temp. At its hottest no hoses are collapsing, and I can see through the radiator coils, there was some debris I was able to clean out but not severe enough to consider a blockage. There are no other leaks, and after running a bore scope through the radiator end tank I'm not seeing any visible signs of internal blockage. I thought maybe head gasket leak, the car has arp head studs, and there is no oil in the coolant and no coolant in the oil...
What's next?
I have searched and searched over the last month with no real result, running out of ideas. Any help or ideas are appreciated.
Old Jun 1, 2018 | 07:38 AM
hayseed's Avatar
04 e55
do a pressure check on it and leave it on for 30 min and see if it drops - could be a flow issue - check flow out of water pump and also look for kinked hose, may be blockage etc you may have to do a good flush again. -
