Cable routing
Old Jun 11, 2018 | 07:37 AM
Pieter Schepers's Avatar
E55 AMG Wagon
Cable routing
What is the easiest way to get cables from the cabin to the engine compartment without drilling holes? I want to install an afr gauge and oil pressure gauge.
Old Jun 11, 2018 | 10:45 AM
brdaun's Avatar
E55, CTS V
When i plumed my fuel pressure line there is a gap in the wall above the pedals that leads into the fuse box, i managed to feed it through there. Was more consuming then one would think as i couldnt really locate much for pass throughs in the firewall.
Old Jun 11, 2018 | 01:42 PM
seanol's Avatar
2004 AMG E55
There are a few I have used, one under passenger side air box. Grommet below the cabin air filter box. There is also a grommet on the side of the transmission tunnel on drivers side that can be seen from underneath car. Last is one right near the Ecu.
Old Jun 11, 2018 | 02:07 PM
mbmg's Avatar
2004 E55
For my ZT-2 data logger EGT and wide-band cables I used the grommet near the ECU passenger side foot well. For all of the other sensor wires I ran them through the passage under the driver's dash near the brake pedal (E55 left hand drive) that goes through the front SAM on the driver's side engine compartment. If you put a light under the dash you can better see the passage when looking down at the back of the front SAM.
Old Jun 13, 2018 | 11:44 AM
E55 AMG Wagon
I ended up using the grommet in the trans tunnel. Still have some wiring to finish, but all cables are in place.
Old Jun 13, 2018 | 11:59 AM
mbmg's Avatar
2004 E55
looks good
