Weird rear end problem
Old Aug 21, 2018 | 12:13 PM
E55amg0220's Avatar
Veteran: Air Force
2003 Mercedes E55 AMG
Ok while changing my rear tires yesterday i noticed that the tires are rubbing the shocks here an there. These are stock rear rims an tire size 265/40/18. I know it cant be the rear subframe bushing being bad cus the shocks would move with it but if the tires can somehow move side to side then this would cause it. Anyone have this issue an if so what was the cause an fix??
Old Aug 21, 2018 | 12:40 PM
N_Rob's Avatar
2008 BMW M5, 2004 E55 AMG (RIP)
How’s your camber?
Old Aug 21, 2018 | 12:42 PM
E55amg0220's Avatar
Veteran: Air Force
Originally Posted by N_Rob
How’s your camber?
camber is good just had the alignment done an looks great but may have it looked at again to make sure. Had les schwab do it they seem to do a good job ea time.
Old Aug 21, 2018 | 12:46 PM
N_Rob's Avatar
that’s honestly the only thing I can think of. These cars are heavy, maybe the car is flexing the tie rods when a lot of stress is put on them like a bump. That is, depending on how new your suspension components are
Old Aug 21, 2018 | 12:51 PM
E55amg0220's Avatar
Veteran: Air Force
i may need to freshen up the rear suspension but seems ok but i did redo the entire frt maybe its time for the rear as well haha.
Old Aug 22, 2018 | 05:10 PM
£ C43 £ AMG £'s Avatar
E55K AMG
camber might be fine, but this bush effects toe on the rear on the rear if its worn, generally people rarely change this bush because sometimes it requires the whole arm to be replaced
Old Aug 22, 2018 | 05:14 PM
E55amg0220's Avatar
Veteran: Air Force
Ill look into that thank u
Old Aug 22, 2018 | 05:45 PM
E55K AMG
your welcome , jack up the car and pull and push the wheel left and right.
The bush can be bought separately, but the arm is in two parts and it has a lip pressed together around the bush from the factory, You cant just press in a new bush unless you remove the arm and twist the two parts apart, but that will require deflating the suspension airbag.
If you dont want to remove the arm from the car you can extract the bush by grinding away the lip on one side of the arm around the bush.
Old Aug 22, 2018 | 06:34 PM
E55amg0220's Avatar
Veteran: Air Force
Ive installed a arnott air to coil conversion on mine already so not worried bout deflating. Ill take a look at it tomorrow an see if it feels solid
