Fixed Pulley Discussion
/3.5%20and%20updates/CDSP-888x1080.jpg)
But then there are normal clutchless pulleys you can put on and off just as any other pulley
[img]http://vrpspeed.com/image/cache/catalog/products/e55(10)/3.5%20and%20updates/CDSP-888x1080.jpg
if supercharger isnt driven it no boost and low throttle = open loop so car manages itself re afr. Even at WOT the map would keep safe just might trigger CEL for airleak or supercharger failure if you WOT it but tuner can clear that obviously..
headers safe to drive without tune IMO just dont see power gain fully.
honestly tw2 idea is good too, id reccomend test fit fsp then put old one back on so you know how many shims you need etc. It should be easy to torque off once youve initially broken it, usually theyre seized on the first time making the extremely easy job of replacing the sc pulley a little more hassle.. I have no idea how quickly the bolt gets hard to remove, maybe a couple heat cycles.
But clutch delete pulleys are getting more and more popular and we haven't been running into any drive-ability or tune-ability issues. The car does feel more responsive with a clutch delete by a long shot even vs a standard fixed.
Really hard to get over how great they look aswell
Honestly you will get better answers if you spend time reading. So many posts and questions come up that are utterly useless because it has already been asked and the knowledgeable guys are repeating this info to you.
Put a factory bearing back in, if you couldnt notice the sound of your factory pulley literally sh*t its bearings out then you really need to familiarize yourself with the vehicle.
On the VRP website it states that if you use the “clutch delete” pulley it will be necessary to press off the clutch pack, and then it will not be possible to use “stock” or “ clutched pulley” afterwards.
This is install on a 04 SL55 with 2nd HE and bosch 010 pump wire to be always on. OEM exhaust OEM intake.
installed 77mm FSP with RIQ tune. it is the same black FSP, prob a UPD brand one. It is day and night. So much more response and power. Tony say I should have 490hp w 550tq at the wheel.
What I notice is .
1. immediate power. response is huge difference compare to stock pulley and tune. It is truly a beast. Scary to drive at first. got a little use to it but still scary fast.
2. trans is shifting harder with the added power.
3. No more that little squeak sound when I'm driving slow in parking lots when Im pressing the accelerator to manipulate slow roll
4 No noticeable rattle sound that people talk about with FSP in engine idle. - i did change the SC oil at the FSP install. if that's anything worth mentioning.
5. No noticeable difference in MPG. It is still pretty crappy at about 15mpg
6. SC whine!!! is intoxicating.
