"Lean Map issue"
Random lean spike that stays locked in until you shut car off for key cycle and yes fuel pressure was on the money.
I ended up putting a map clamp on and set it to 4.3 volts. this way if the ECU ever see's a "funny" off the scale output/input reading which normally pegs the map reading, it will no longer do that.
One thing that I swear by is the AEM fail safe. I have it set at 12.1 AFR so any reading over that the compressor will become disengaged. There is no way to "blow up" your engine do to a lean out and you never really have to pay attention to anything while beating on your car. Has saved the day 3 times since I bought it. No brainer!!
Side note to SICAMG, the Aem fail safe gauge looks great and sounds amazing with the built in fail safe feature. I dig the sound of that. As a matter of interest how did you wire up the fail safe that the gauge sends the signal to shutoff the SC when you get into the lean scenario?
The unit is wired directly, "relay" into the power line to the compressor clutch. As soon as it is triggered from the gauge it will interupt the supercharger signal and shut off the compressor for 10 seconds. After 10 seconds it will turn the compressor back on. The time is adjustable as well and 10 seconds is more than enough time to figure out "Hey? what just happened"
The unit is great and It's always on and set so you never have to think about it for any reason.
It is a little pricey for what I use it for considering the gauge is wrapped in plastic and hidden under the ice box under the hood. I have data recording and a stand alone wide band so my AEM is only to serve as a fail safe only..
