E55 Engine Clearances
Old Sep 15, 2018 | 11:51 AM
N_Rob's Avatar
2008 BMW M5, 2004 E55 AMG (RIP)
Hey guys, this may be one of the stupidest questions ever asked on the forums so I apologize in advance, but I'm being paranoid about it. I suspect my engine mounts are going bad based off of the vibrations I've started to feel in the car while idling and such and had planned to replace them within the next month. Just yesterday I fell victim to the infamous crankshaft position sensor failure on my car. I managed to restart it and get home without the car dying on me and started poking around the engine bay trying to locate the sensor, which I found. However while I was in there, I couldn't help but think that the engine had moved farther up the engine bay than I remember it being so I wanted to get you all's opinion on it. It seems I can see more of the firewall than I remember and the front engine cover looks way too close to the fan assembly, I can barely fit a finger in between the two. Maybe it's nothing, but I wanted to make sure. And if it is sitting too far forward, could worn engine mounts be the culprit? I can't imagine they would have degraded that fast a week after I felt the symptoms but I don't know. I won't be driving the car for 3 or 4 days while I wait for the crankshaft sensor.
Old Sep 15, 2018 | 03:20 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
Search about it, there is lot of info around, easy to check. Front to back flex is not what you are looking for with the mounts, it's rotational.
Pop the hood, turn the car on, punch the gas. The driver side of the motor will lift and the passenger side will sink. I can't remember what to look for exactly but it shouldn't lift more than like an inch or so when you punch it with good torque. If you can roll on throttle and watch the engine walk upwards a couple inches it's probably toast.
Old Sep 15, 2018 | 03:42 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
You can also get under the car and look for orange staining from the hydraulic fluid that has leaked out of the mounts.
Old Sep 15, 2018 | 04:00 PM
new55's Avatar
04 55
Originally Posted by N_Rob
r.
sorry for hijacking this thread/picture but how do you take these clamps off without screwing up the clamp ? - do you need a special tool ?
Old Sep 15, 2018 | 05:35 PM
tw2's Avatar
tw2
That is normal position for the engine. I don't run the front cover due to scatter shield. Behind the engine you should be able to fit you hand down just to get at the transmission filler etc. Go to approx 9min 30 sec
And this one also around 9 min 30 sec conincidentally. Looks like it is going to jump out and eat you.
For the intake? Best not to. Pull the tops of the airboxes off with the full Y pipe from the throttle body as one piece.
Old Sep 15, 2018 | 06:01 PM
tlambert's Avatar
2005 E55 AMG
Originally Posted by tw2
I don't run the front cover due to scatter shield. .
Why is this?
It was designed to do so.
Old Sep 15, 2018 | 06:21 PM
tw2's Avatar
tw2
Originally Posted by tlambert
Why is this?
The re-installation of the cover was not completed due to an odd scientific anomaly known colloquially as laziness. It also means I am much more likely to check the pulley springs if I don't have to remove the cover each time which is what the shield designer intended.
Old Sep 15, 2018 | 06:44 PM
tlambert's Avatar
2005 E55 AMG
Haha good description. I get that way sometimes.
but clip, clip, clip and it’s off. Now that’s lazy. Haha I get it.
Old Sep 15, 2018 | 06:58 PM
Strigoi's Avatar
Those covers also break easily. Years of getting hot and then cooling down doesn't bode well for plastic. I broke off one end of the one on my E63 when pulling it once. According to a dealer tech I know the covers breaking is a very common issue. Luckily the E63 ones are cheap.
If you're pulling it on a somewhat regular basis to look at stuff, I'd just leave it off.
Old Sep 16, 2018 | 03:35 PM
new55's Avatar
04 55
doesnt the y pipe have the same clamp to the TB ? Need to go take a look. Thanks
Old Sep 16, 2018 | 03:53 PM
tw2's Avatar
tw2
No. It just kind of clips in with a couple of plastic tabs.
Old Sep 17, 2018 | 12:20 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Yes, and they are stupidly expensive for no good reason, but they make the job easy. Google "EZ Clip Pliers". Look for the ones with green handles. They are meant for working with EZ Clip AC fittings, but work the same on these airbox clamps.
