Brazing Rods To Fix Aluminum on My Motor
Do yourself a favor and get a new front cover so you're not doing the job twice.
Obviously replacing the cover is the "best" route, but that's a lot of work so I would definitely try some repairs first.
I wouldn't recommend brazing that. I would worry about cooking the sealant and causing leaks and/or setting some oil or hoses on fire because it will take a LOT of heat to get that thing anywhere near hot enough to braze (and no matter how well you clean it, there will be oily residue left in places). It might be possible to braze that successfully, but I wouldn't want to risk it. Maybe with a lot of experience, but the amount of heat you would need will make that extremely difficult to pull off.
Personally, I would TIG weld it with just a few tack welds to prevent getting it too hot. It shouldn't be hard if you can get the tig torch in there... probably won't even need any filler.
TIG welding is much stronger than brazing in most situations. There are certain cases where brazing can be stronger, and I suspect that this might be one of them (brazing should join the entire broken surface while welding will just join it at the outer edge), however, strength is a non-issue in this case. If either process is done half-way right, the repair would be far more than strong enough. In this particular case, TIG welding should be easy, whereas brazing that (even with a lot of experience) would be extremely difficult. Even if it didn't go very well, TIG welding this would likely be successful, whereas brazing would need to be done properly in order to work.
If you can't (or don't want to) TIG weld it, you might even try JB weld as a last resort. Sure, it may fail, but I've seen it hold on similar things with much higher stresses than that and you don't really have a lot to loose. Just make sure it's VERY clean first and give it at least a full 24 hours to cure.
Whichever way you go, use a slightly longer bolt afterwards to catch the threads past the break.
