VRP Belt Wrap kit Issue
Old Oct 12, 2018 | 11:54 PM
precisionmike's Avatar
2003 C32
Hello,
I am installing a very slightly used VRP BWK. After installing the pulleys, I noticed there was a fair amount of play, you can wiggle them back and forth. The bearings are fine, but it appears the pulleys were machined too deep, causing a gap between the bearing and the edge of the pulley. Has anyone else seen this? TIA, Mike.
Old Oct 14, 2018 | 07:03 PM
gjunon's Avatar
04 E55 AMG
I have never seen this. I personally would not use a pulley that has that much play in it. Can you add a spacer to reduce the play?
Old Oct 17, 2018 | 10:56 AM
karpetcm's Avatar
2006 E55 AMG
I hope this isn't going to be my case just ordered a BWK from them.
Old Oct 17, 2018 | 05:42 PM
PieRat's Avatar
CLS55
Should've gone UPD/Shardul he does good deals if you hit em up and the quality is good and original creators of BWK AFAIK.
