E55 maintenance
rear diff service
trans service
coolant flush
valve cover gaskets - small leaks , right more than left, but thought I would get it done.
spark plugs - factory plugs were still in place after 14 years.
V-belts - showing signs of mild dry rot.
main battery - bad
SBC aux battery - weak
front control arm bushings replaced on both sides due to both being cracked.
4 wheel alignment alignment
Service D ( showing that its due on the dash ) - included oil change, brake fluid change, cabin filter, AC service, lube door jams, sunroof rales.
Both air filters.
Ordered extra Key from the factory.
one small right front fender dent repair.
wipers
Should be good for a while now, I hope.
Amount paid: 4900. Priced this out with various Independent reputable shops in the area - some services were less, others more, probably would have saved 300-400 bucks over the dealer. What do you guys think, reasonable or did I get hosed?
Could you have saved some money in the aftermarket compared with the dealer? At $150/hr and the dealer charging 2.5 hours to service the transmission, another 2.5 hours for your 'D' service + upsold items... Sure... But MB uses only MB parts in your E-55 with techs who work on MB all day every day. That is worth something.
edit: How many hours of labor did MB charge to do your engine mounts? Look on the repair order. I want to know.
If you work with a shop in the aftermarket and have good rapport with them you can ask what flavor of parts they use.... Where you are well versed in such things you will know well enough to insist on genuine AMG air struts when those are needed... That ATE dot4 brake fluid is just dandy rather then spending extra for the bottle MB sells.
One needs to be sharp about how the car works to ask the right questions + know about what he is telling you. If you're not that kind of mechanically inclined... That is OK... Take it to the dealer and know that it has the best chances of being treated right there.
