Power Steering Pump/Res Replacement
Old Dec 20, 2018 | 05:39 PM
anomadtoo's Avatar
09 E63
Hello all,
I'm going to attempt replacing the pump and reservoir myself, parts are on the way. Any suggestions/tips you all can share? if so I'd greatly appreciate it.
Also, regarding the reservoir; are there or were there, new seals that come with it or that I need to order separately?
thank you! learning as I go
Old Dec 21, 2018 | 09:06 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
When I bought the reservoir for the M156, it had the cap & cap seal with it. Make sure to get the updated reservoir. Valuable info in here:
https://mbworld.org/forums/w211-amg/...tructions.html
Good luck.
Old Dec 21, 2018 | 11:01 AM
anomadtoo's Avatar
09 E63
thank you for the info, I surprised I didn't see that one, grrr. Will go check on the res part number now. And I did what they poster in that did....flush the fluid and the noise got worse, so it seems if I would have caught it earlier on the res could have been the only thing to replace (possibly). oh well
again I appreciate it
