W211 thermostat install ?
I just replaced the thermostat and upper hose two days ago. Recommend you check/ replace the lower and upper hoses at the same time, to avoid headaches later on.
Lower Hose: A2115018982
Lower Hose: A2115019082 (For Canadian Spec cars CODE 460)
Top Hose: A2115018882
Updated Thermostat: A1562030475
If the hoses are in good shape, replace the O-ring A0269976745
Good luck.
Good luck.
Tools needed
- 10mm socket wrench with extension
- Radiator drain pan
- Flathead screwdrivers
Remove the front engine cover.
Remove a few vacuum hoses in front of the PS reservoir.
Unbolt the PS reservoir and move it to the side.
Disconnect the overflow line from the Thermostat with the flathead
Remove Upper Coolant Hose by unclipping the hose and move to the side.
Remove the 3 10mm Nuts, Make sure to remember which ones go where they are different lengths
Remove and Reinstall.
Fill your radiator and bleed.
Tools needed
Tools needed
can you share torque specs on thermostat bolts and the pulled removed to get to oil filter housing? Especially the tensioner pulley. Thank you
