Same stupid noise....oh well
Engine and trans back in and running after a long battle with the custom exhaust system....on my back in the garage,.... and only to have the same ...but better , oil pump whine from engine ! Had a feeling it would be there but hoped for the best. The engine was gone through with a fine tooth comb and every possible avenue was explored for this noise and nothing was found. Even the feared hardened O ring was not that bad so couldn't even point to that.
Anyone know where oil pressure should be hot at idle?
Not really but when cold ….yes. The Bizol oil made a very big difference but always still there. I have heard other cars and they where very loud compared to mine ……..but then again some where much more quiet.
I put in a new pump,chain ,tensioner, bearings on the lower end and although better, still hear it. Mind you that was not just the reason for going into the engine. Head studs arp rod bolts timing chain and some porting and header/exhaust build..{really sucked} where done along with building the trans so if the engine was quieter that would have been great.
$400.00 for rods and 180.00 for mains. Kinda pricey for just bearings and is why I didn't get them coated. Everything else was fairly priced.
Engine also only has 70,000 miles but I figured do it all now so I can go race and crank up the boost for years to come.
Awesome engine to work on !!!
it's the oil pump that makes noise not the transmission
because of the way the M113K is so enormous, it wouldn't fit into the W211 engine bay without modifying the oil pan to fit around the subframe, so there's two separate oil pickups and it's noisier
the S and CL don't need to do this so they don't make as much noise (5:53 in this vid)
i've also noticed the pump is noisier if there's a little bit too much oil in the pan, such as right after changing the oil i'd pour in the full 9 quarts, and i guess since not all the oil had drained the level was still a bit high and the pump was noisier... but after driving enough and oil gradually burns off it quiets down
but this won't change the oil pump making noise
It is believed through our testing that the front scavenge is sucking the front pan dry , giving the cavitating type sound. This was "sort of" verified by removing the front drain plug when the engine was running and very little oil came out meaning there was not enough drain back to the front scavenge to feed the demand from the suction side of the pump. Not a big deal since this is not where the oil supply to the engine comes from, but just a secondary feed to the pressure side.
I could be totally wrong on this as I am not an engineer.
I usually get a couple quarts out of the front when I drain it, but I can't remember if the whine starts immediately or waits a few seconds. I think it's immediate, which would mean it has oil to pump. I'm not an engineer either, but don't sell yourself short. Being sensible and reasonably intelligent goes a long way in this world
Starving ..I never get more than 3/4 to 1 quart from the front.....strange.
We also dissected the pumps to learn exactly how they work. Over engineered as usual LOL but interesting none the less..
I also forgot to mention that I strongly believe that bearing clearance plays a role as well. The more miles, the wider the clearances get with more oil being "used" by the engine and not being "backed up " by way of pressure. So the pump is acting a little different ???? That is why I think oil thickness and cold start play a very large role in the noise due to pressure ??
