Ignition coil clips?
So when I bought my E and first started working on it I noticed most of the clips that connect the wiring to the ignition coils were broken but never had any issues. Today while driving I put my foot down and had the car bog down hard and run rough. Pulled over and found cylinder 8 unplugged. Any clever ideas to get them to stay or buy new clips?
Subd. You can get the connectors new , possibly able to de-pin them would be great if possible ? instead of splicing . A dab of rtv will stop them from coming off temp. fix
i thought about an adehisive - but then if I need to take them off for any reason it makes it tricky. And I’ll be doing the coil packs and plugs in the next year probably.
I saw I have a couple zip ties still in tact but wasn’t sure it was all that helpful based on the placement of them. Will do! Thanks for the advice fellas.
Does anyone know the part number for the connector? I went to local MB dealer and some auto parts store but no body sure what it is. MB parts shop calls it ignition coil plug but the picture in the diagram looks different. I'm not sure that the part I need. Thanks.
Dear friend whats you mean, my car not can damaged coilpack ?
I buy 3 times used module ? For example Buy 1 pcs i see misfire, soldering coils, and module work, but small time, buy another, soldering, work small time and off forever.
But all 3 module working, but small time, #1 2hours, #2 40minutes, #3 (last) 2 minutes, maybe car have problem ?
All 3 module not working now (i disconected right side, and car not start up on left side)
Sorry for my english i use translator, i want buy new coilpack, but maybe car damaged new coilpack ? Real car damaged all 3 used module before, or maybe all module bad ?
how could car damage coil packż maybe you need to check the wires and plugs, only way I could see damage is from some kind of short after the coil pack. the used packs you buy may have been bad Try get new maybe? If new breaks coz of car you can still return as faulty how will they know car did it?
