Flat AUX cable
Old Apr 27, 2019 | 04:34 PM
JB88's Avatar
Fern Green Pontiac Aztek
Flat AUX cable
A cheap solution to using the aux port while wanting to conceal the cable/keep the glove box closed. it's flat and tucks away nicely into the recess.
https://www.ebay.com/itm/3-5mm-Flat-...53.m2749.l2649
Old Apr 27, 2019 | 08:46 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
My glove box stays closed just fine with the AUX cable coming out of it.
Old Apr 29, 2019 | 08:00 AM
chkoo's Avatar
W211 E63, W205 C300
Why are you guys still using aux cable, you can get a 3.5mm to bluetooth module and hide it in glove box!
https://www.ebay.com/itm/APS-Bluetoo...frcectupt=true
Old Apr 29, 2019 | 09:18 AM
JB88's Avatar
I didn't know about this- cool. I will order one.
Old Apr 29, 2019 | 11:11 AM
tlambert's Avatar
2005 E55 AMG
I have the factory BT puck in my car for using my iPhone for calls. I also use the 3.5 port cable in the glove box to listen to music from my iPhone to the car. When I get a call it will automatically switch over to be able to answer calls.
So if I use one of these BT adapters for the 3.5 to listen to music what is going to happen when I get a call?
I beleive the phone won’t automatically switch back over to the puck. I think you have to select which BT device you want to use each time.
It would be great to not have the cable hanging out the glovebox.
So how or will this help in my case?
Old Apr 29, 2019 | 11:49 AM
farkis644's Avatar
00' W210 E55 (sold), 07' W211 E63
Where did you tap into for power? Was the cable long enough? What did you need to remove?
Old Apr 29, 2019 | 12:03 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
I have have the factory BT puck and a Bovee BT adapter for the 3.5mm cable. My music and phone work seamlessly; music through the Bovee and phone through the puck. Incoming calls always go through the puck - not sure how it works so well but I do see what you’re saying.
Old Apr 29, 2019 | 12:19 PM
tlambert's Avatar
2005 E55 AMG
Are you using an iPhone?
Link to the Bovee you bought?
Old Apr 29, 2019 | 08:23 PM
cfmistry's Avatar
Yes iPhone X.
https://www.amazon.com/Bovee-Wireless-Bluetooth-Interface-Integration/dp/B00B52LLJ6/ref=sr_1_fkmrnull_1_sspa?keywords=bovee+benz&qid=1556583707&s=gateway&sr=8-1-fkmrnull-spons&psc=1&smid=A3Q6OU3JUZJQCD https://www.amazon.com/Bovee-Wireless-Bluetooth-Interface-Integration/dp/B00B52LLJ6/ref=sr_1_fkmrnull_1_sspa?keywords=bovee+benz&qid=1556583707&s=gateway&sr=8-1-fkmrnull-spons&psc=1&smid=A3Q6OU3JUZJQCD
or something very similar (can't remember the exact one). I had the iphone connector in my glovebox, not the 3.5mm aux.
Old Apr 29, 2019 | 09:35 PM
N_Rob's Avatar
2008 BMW M5, 2004 E55 AMG (RIP)
Wondering this too. How are you keeping the Bluetooth connector charged in the glovebox?
Old Apr 30, 2019 | 08:37 PM
Strigoi's Avatar
It works. I'm not into all this fancy schmancy new **** so I do what works.
I'm happy with my $100 Virgin Mobile phone that I can use to listen to Spotify through the aux cable (and text and play some games on). I don't need to **** with that Bluetooth stuff. I still use CDs that I burn in my truck since it just has a 6 disc in dash CD changer.
Old May 1, 2019 | 11:53 AM
E42AMG???'s Avatar
E420
Fear change!!!!
Old May 2, 2019 | 03:00 AM
chkoo's Avatar
W211 E63, W205 C300
i took power from the 12v cigarette lighter, phone calls do not work through the bluetooth module (at least the one that i have).
