52 LB INJECTORS
Kind of an open question I know, but what point do you need bigger injectors?
PLATINUM SPONSOR
Tune , pulley and headers =injectors for safe insurance. OEM injectors are real old now and low pressure or failure can be bad news on a boosted engine.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
The following 2 users liked this post by Exotic-metal55:
Fountain35 (04-30-2019),
MSG 55G (05-01-2019)
I thought i was ok because i was still seeing 10.8 afr.no matter what until i realized my injectors were just going static an staying open. Now with 550s afr is perfect at 11.5 at wot and idc is in the low 80%.
