Which spacers for the rears?
Old May 1, 2019 | 11:37 PM
karpetcm's Avatar
2006 E55 AMG
Im looking to slightly get a better stance by pushing the wheels out a tad, 5-8mm spacers for the rear. Before anyone says spacers are bad or get wider tires I’d like to see if anyone can help out with the right type of spacer i would need. The help would be greatly appreciated.
Old May 2, 2019 | 12:01 PM
Windowguy's Avatar
2012 Audi S4 & 2008 E63 AMG
On my 2008 E63 I used spacers that I got from ECS. I think they are 10 or 12 mm. I also got longer bolts. I am at stock ride height and the wheels are almost flush. They definitely do not stick out.
Rob.
Old May 2, 2019 | 12:03 PM
karpetcm's Avatar
2006 E55 AMG
Rob.
i think if i go with 8mm hub centric for the rears with the longer bolts i should be fine. Im lowered but my rear quarters are rolled.
Old May 2, 2019 | 03:02 PM
boosted305's Avatar
broom
https://mbworld.org/forums/w211-amg/...ml#post7712614
I went with 10mm Front and 12mm Rear H&R hubcentric with 40mm lugs...came out perfect
H&R Spacers:
20556659 (10mm FRONT ONLY)
2455665 (12mm REAR ONLY)
Lugs:
https://www.ebay.com/itm/Silver-Ball...72.m2749.l2649
Old May 2, 2019 | 03:32 PM
karpetcm's Avatar
2006 E55 AMG
Ok perfect thank you 🙏
H&R Spacers:
Lugs:
Old May 2, 2019 | 05:26 PM
tw2's Avatar
tw2
I don't think anyone is against spacers if they are done properly and within reason which you are. Using longer bolts of course with slip on spacers. Using a hubcentric design. If they are over a certain thickness (10-15mm) then you will need bolt on hubcentric spacers at which point only buy reputable very high quality products, your wheel staying on depend on it.
Old May 3, 2019 | 06:16 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
I ran 20mm spacers in the rear on my stock wheels and tires and it looked great, no rubbing.
Old Feb 16, 2020 | 11:47 AM
mrcbr600's Avatar
335i
Bump for any recommendations... wanting to run some 15mm up front on 2020 wagon. Thanks for any suggestions!
