LegitStreetCars & Southern HotRod valve body
When you hit the paddle shifter it signals the transmission to change gear, and I don't think the transmission sits in a ready state to change gear hence we get the 500ms odd delay. This means from the time the transmission received the signal, it begins to prepare for a shift and then and executes it. In sports or comfort mode, the transmission decides based on driver input to select a shift point. So if you press the foot flat it will switch at redline. Let's say red line is 6500, when the car hits 6,000 rev's it will signal the transmission and the transmission will prepare to shift and then shift. This shift then occurs conveniently at 6500 on time for red line.
Im glad you clarified alot of questions that i had in mind about this valvebody. I currently have this setup on my cls55. Its doing exactly that of what you mentioned. Only downside for me is the delay upshift in manual and sometimes the slight harshness when you get on it!
Also if you transmission is in good working order a valve body will work fine regardless of age but if your transmission is shot a valve body will not fix that. It may help keep it going but it is not a bottle of magic that can fix a worn out transmission.
Additional clutches will help hold more power. But it also will make it more harsh. I have people making well into the 700whp mark and above on the 150% vb on stock transmissions. If it shifts firmly then there is not a benefit to a built transmission in addition to the valve body. If it is still slipping or slow to shift it may just be your transmission is shot or you are making a lot more power or your engine tune is lying about how much torque it is making and no amount of clutches and valve body upgrades will help.
my transmission per master tech stated, shifting too fast/hard, so the computer is actually adjusting and tapering it off.
best bet would be programmable Transmission Controller Computer if looking beyond a valve body.
past experience in valve body mods have me believing decrease accumulator port size and increase control pressure are easy.
Hence Maybach solenoids are the quickest mod but pricey.
Cheers, Gator
Cheers, Gator
Nice vids you guys!
