problem removing the plug from the crank position sensor
Old Jun 7, 2019 | 11:40 PM
1ottawa1's Avatar
e55 amg ml350
I can't seem to get the tab to lift up off the sensor
Old Jun 10, 2019 | 10:14 AM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
Skip directly to 3:19
Personally I use a mini pick but you run the risk of snapping off the plastic tab....you've been warned
Old Jun 10, 2019 | 11:03 PM
rttadam's Avatar
c36amg e55 amg e500 wagon
Some jobs you should ask your wife for assistance....
Old Jun 12, 2019 | 12:12 AM
1ottawa1's Avatar
e55 amg ml350
I got it!!!
https://www.youtube.com/watch?v=QYhYx6XlIok
when I saw you take the whole assembly out as one after removing the e8, I tried it from underneath the car. got the e8 out, pulled out everything and used a pick to separate. many thanks. good job!!! bill
Old Jun 12, 2019 | 12:13 AM
1ottawa1's Avatar
e55 amg ml350
I can't. she is asleep. .......
Old Jun 12, 2019 | 11:22 PM
1ottawa1's Avatar
e55 amg ml350
e55 amg 2005 crank position sensor removal
on the e55 it is easier to take this out from underneath the car if you have a lift available. if you disconnect the o2 sensor wire on the right rear of the engine and then remove the 2 bolts on the left side, you can move all the sensors off to the left and see the crank sensor. the torx bolt can be removed with a e8 socket and a 1/4 socket.
Old Jun 13, 2019 | 05:14 PM
FunkTron's Avatar
2006 CLS55
Asleep on the job......
