Power power other than more boost
Old 07-04-2019, 07:07 AM
V8Displacement's Avatar
55
Hello fellow E55 owners
other than exhaust what can i do to increase the torque and hp without adding more boost?
Old 07-04-2019, 07:49 AM
hayseed's Avatar
04 e55
diff gears
V8Displacement (07-04-2019)
Old 07-04-2019, 07:54 AM
55
Nice idea any more info
Old 07-04-2019, 09:36 AM
AMG__POWER's Avatar
2023 e450 cabriolet, 2015 s550, 2024 c300 , 2006 E55, 2005 e320, 2007 gl450,
Pm’d
Old 07-04-2019, 03:54 PM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Headers is about it.
V8Displacement (07-05-2019)
Old 07-05-2019, 08:31 AM
55
Pistons
Can i do any upgrade to the pistons
Old 07-05-2019, 08:46 AM
kenneyd's Avatar
poop
Pistons will do zero for power. People really only change pistons to either allow more boost via strength and compression changes. Also, they are the least cost effective, since the motor will have to be completely torn down.
Cold air intake, throttle bodies, Headers, mufflers, tunes are probably the easiest mods, but they wont net much power with the exception of long tube headers, A few members have claimed 25-30hp with long tubes.
Typical motor mods generally include cams, and ported heads. Both of which are uncommon for the e55 as far as I know.
Old 07-05-2019, 09:25 AM
55
My friend tried porting and gone wrong , his mechanic told him to do only polishing but he insisted,
what internal changes I should do to increase the boost to the maximum safely
Old 07-05-2019, 10:07 AM
AMG__POWER's Avatar
Tune pulley headers and cooling is the best and easiest way to make power
Old 07-05-2019, 11:26 AM
55
We already finished that and looking for what’s next level
Old 07-05-2019, 11:30 AM
kenneyd's Avatar
poop
If you've done all that and still want more, time to buy a cts-v or w213 e63
Old 07-05-2019, 11:38 AM
55
Don’t say that please there should be more I see people changing pistons , sleeving and reporting more power
but i have zero idea what they do exactly
Old 07-05-2019, 12:51 PM
AMG__POWER's Avatar
Weistec blower and cams
Old 07-05-2019, 01:11 PM
drothgeb's Avatar
2005 E55
Up the compressor ratio by switching over to an NA block, a few threads around here on it.
Also several threads around here on changing gears. Most guys end up going back to stock it seems. I haven't read them in a while but upping the gears puts the fourth gear shift right at the end of the 1/4 mile killing the ET... if 1/4 mile is what you're looking for.
Old 07-05-2019, 01:14 PM
55
Thank you very i will look into the block advice
and i’m all about acceleration
Old 07-05-2019, 07:20 PM
tw2
tw2's Avatar
+1 you can make the E55 very fast but there are much better options out there. Traction and cooling becomes a huge issue, finding am AWD platform with turbos would be ideal. Are you drag racing or just street?
It is easy to get a bit more power out of these cars but it becomes difficult to get a lot.
Old 07-06-2019, 01:18 AM
55
Still street , can’t go to drag racing knowing i don’t have a chance to win
I agree with you on traction LSD is a good idea and still researching Bout the widest i can go (offset and tire size) with out rubbing
Old 07-06-2019, 02:42 PM
SICAMG's Avatar
2005 e55 AMG
I can tell by your question …..you are NOT going to change the block. Actually there is no reason to change the block. Pistons...yes, for more compression. Cost would be huge to go down that road though.
Put headers on it , crank boost to 14-15lb's, add extra intercooler, mod the supercharger cooler, add ice tank for the track and a small shot of nitrous. You will be very happy.
Old 07-06-2019, 04:10 PM
55
I have this extra crazy idea
i know a guy he used 63 pistons and ported the block but failed
so what if i used the block and pistons of 63
Old 07-06-2019, 04:48 PM
tw2
tw2's Avatar
And the single cam heads of the M113? Sounds like a perfect match. I'm sure the oil water bolt holes and cylinders line up. The answer is to be happy with the confines of the M113 or change platform.
Old 07-06-2019, 05:07 PM
55
Changing the whole car is going to be difficult
but finding a used engine and part it use what i need and sell the rest for sure will be cheaper than a new car with new unknown problems and fixes
Old 07-06-2019, 06:00 PM
tw2
tw2's Avatar
I'm sorry to say, that plan with engine mix and matching will not work. If it could, chances are the machine work and custom parts required to make it work would cost more than the car.
Old 07-06-2019, 06:01 PM
tw2
tw2's Avatar
I should also point out that air flow and hence power is created in the head, not the block. Changing blocks and pistons won't get you far.
V8Displacement (07-06-2019)
Old 07-06-2019, 11:31 PM
55
I guess it is too crazy ,
face the limit
Old 07-06-2019, 11:34 PM
black06c230's Avatar
2012 Volt - 2005 E55 - 2011 G55 - 2013 GL63
Meth injection
Quick Reply: Power power other than more boost
