KILLER CHILLER Drag Kit worth it?
Old Dec 17, 2019 | 10:06 AM
  #51
MSG 55G's Avatar
Veteran: Army
2006 E55
Trunk tank; max efficient size
Speaking of tank, I’m in the process of running a trunk tank, I have the hoses and a 5 gallons fuel tank that my buddy gave me which I converted to an ice tank. It’s ready to install and routed but I also ordered a 7.5 gallons ice tank. Would 7.5 be too much for KC to cool down? I’m using secondary rule 2000 pump as well.
Fuel tank had a very small opening that I had to cut to 6” I order to fit internal pump, bought lid from amazon and it worked out perfectly
insulated tank to prevent dripping and keep it cooler.
Old Dec 19, 2019 | 05:24 PM
  #52
SICAMG's Avatar
2005 e55 AMG
MSG......I have a sensor in the tank and the other is in the intake, again a stand alone set up and separate from the OBD.
Old Dec 21, 2019 | 06:21 AM
  #53
MSG 55G's Avatar
Veteran: Army
2006 E55
thanks SICAMG, going to local electronic shop for wires to rig tank sensor. Long one!
Old Feb 17, 2020 | 11:18 PM
  #54
MSG 55G's Avatar
Veteran: Army
2006 E55
Rigged up trunk tank thermostat this past weekend right before track day. Such a comfort peace of mind to know how cool the fluid coolant in the tank is with quick glances instead to hooking up OBDII then log on dash command for IAT data that eventually disconnect all the time. During a hour delay siting at the stage lanes, luckily I filled my 5 gallons tank up with nearly 20lbs of ice and it was still chilling at 31.8 prior to my burn out. Ran a PB at 11.4, 1.5 60’ but horrendous trap speed 115mph. Oh well, more track time for me.
Thank you to all (Trabots & SICAMG) that suggested to rig up tank thermo. I love it! 🙏🏻
IAT reading at the end of pass
Old Feb 18, 2020 | 11:27 AM
  #55
chawkins2001's Avatar
2006 E55 AMG
WOW That's awesome bro, great IAT's at the end of the run Do you have your time slip to share?
Old Feb 18, 2020 | 11:33 AM
  #56
MSG 55G's Avatar
Veteran: Army
2006 E55
Thanks chawkin, I do have slip but was gonna post on new thread to comment on my HSTC. I fell asleep before I could finish. 🤣
I’m in right lane, smoked a Cobra Terminator 😂
Old Feb 18, 2020 | 12:23 PM
  #57
tlambert's Avatar
2005 E55 AMG
Nice!
Cool helmet.
