W211 E63 hitch?
I'm searching for threads and haven't found much yet, for my 2007 E63 what is a good hitch solution (perhaps hidden/low profile)?
e-trailer have one for same generation E-class but say it doesn't fit E63...don't know why, maybe there are some differences in the mounting area??
Anyway, I need to occasionally hook up bike rack to rear, utility tray, or other hitch related things. I've had hitches on all my sedans and find them very handy for specific trips and tasks, nice to remove the accessory and back to a normal looking rear.
Cheers!
Scott
Cheers!
Scott
https://www.westfalia-automotive.com...204600001-310/
Will also try to find some under / rear photo to make visual comparison of what if anything different, that would be impacting install of the regular E-series hitch.
If the hitch does fit it will require trimming of your factory rear bumper as on my 2003 Audi A4, I had to do so with its factory non sport bumper. Sport bumper would require much more material removed to clear. Additionally for my Audi I had to remove the rear bumper metal reinforcement because it would require about 6 hours labor to chop up to mount over the hitch structure. Not sure if that's recommended or even possible.
they are not listed for amg cars but as i mentioned earlier i have mounted a westfalia on my e55 amg wagon without problem,no cutouts on bumper either.
I ended up moving to this unit which is a ZERO tap system. It uses magnets or something along those lines to sense electricity across the wiring when you press your brake lights. I paid $109 for this unit on ebay. It works flawlessly.
Tekonsha (119250) T-Connector
Price:$123.31
- Activates a trailer's stop/turn/tail/running lights without cutting or splicing into your vehicles wiring system - simply snap on included current sensors
- Use when: trailer has more than 1 light assembly per side and is equipped with multiple clearance or running lights; if tow vehicle may tow a variety of trailers; if tow vehicle has 'lamp out' sensors
- Re-settable short circuit/overload protection - guards itself and the tow vehicle from shorts and wiring install mishaps; rated at 4.2 amps for turn/stop circuits, 7.5 amps for taillight circuit
- Works on all vehicle types including standard, PWM and/or multiplex systems, ensuring full brightness of the trailer lights during operation; can be used on 2 or 3 wire systems
- Works with either LED and/or incandescent bulbs (vehicle & trailer); includes comprehensive instructions; backed by Tekonsha's 1 Year Limited Warranty
Product description
