Engine Coolant Level
So I filled it up, fast forward to Monday, I did another pre-trip inspection before heading back home, and the coolant was low, so I again filled it up.
Come Tuesday, I checked it again, and the level was at the same level that it was filled to on Monday, the same for Wednesday and again this morning.
Why would the coolant be down, for two straight days in a row, and the last three days the level is full. Someone explain this to me. I was thinking that I have a leak somewhere.
I just had the radiator replaced a few months ago, and last year I replaced the coolant reservoir. I informed my tech that I will monitor it, and provide feedback.
This is really baffling.....
I'm prepared to monitor this for a bit longer. Don't want to over react, I'm planning on visiting my shop next week anyway, for them to do a pressure test of the system. If the coolant level shows signs that it is down for whatever reason, I will take it in sooner. Also I'm installing my new CF instrument cluster cover. And if it has arrived in time, install my new CF interior trim pieces. It may be a blessing that I'm getting new head bolts installed next month. Fortunately, no white smoke from exhaust, which is a good Omen. Last edited by Yuille36; Aug 22, 2019 at 08:52 AM.
I know that we have an overflow, could that have caused the heated coolant to discharge, thereby given me a low coolant level. I tried a experiment this morning, by driving the car with the heater on.
I then checked it again, when I filled up with gas, and the coolant level did increased the the point where some overflowed out of the reservoir, keep in mind that the coolant wasn't blazing hot, but hot enough to get burned.
I think that might have been the cause of my issue. Any opinions on this???
And has been normal ever since Aug 20th. I understand expansion and contraction, with regard to fluid dynamics. So I thought maybe, I had a coolant leak somewhere.
I will follow your guidance, as they will have to pressure test the system anyway after replacing the head bolts.
It was hot when I had the coolant changed last. So go figure.
