E55 AMG Fuel Pump Relay upgrade/replacement? AEM pumps
Hey, I had some fuel issues a while back. I have 2 AEM 340LPH pumps in the car now, and back to the stock wiring harness/tophat. I keep melting the relay on the actual harness itself in the trunk. I've gone through two of the relays with the same issue happening after driving the car for over 2 hours.
Is there an upgrade socket/relay that I could sauder/crimp onto the existing wiring?
Those are serious pumps and draw a lot. Have you checked the draw on those compared to the OEM pumps? Unless you are running E85 you are "over pumped". I would guess those pumps, not the relay is the problem.
AEM 340 LPH E85 Fuel Pump
AEM’s High Flow In-Tank Fuel Pump is designed for high performance naturally aspirated and forced induction EFI vehicles. It delivers reliable performance and high volumes of fuel flow for roughly half the cost of comparable performance fuel pumps.
TECHNICAL SPECS:
Weight: 10.4oz (294grams)
Outside Diameter: 39mm OD
Length: 65mm
External Materials: Black plated steel with laser etching, green/gray end caps
Inlet Fitting: 7.7mm ID, 11.0mm OD. Offset Inline
Outlet Fitting: 8 mm hose clamp. Offset
PRV Activation: 80 PSI
Impeller Design: Single Scroll Ceramic Turbine
VOLTAGE SPECS:
Connector Terminal: 6 mm Spade (pos/neg)
Min Voltage Input: 6 volts
Max Voltage Input: 18 volts
Current Draw (40 psi): 12 amps (13.5v)
Current Draw (80 psi): 15 amps (13.5v)
Fuse: 20 amps (13.5v)
TECHNICAL SPECS:
Length: 65mm
VOLTAGE SPECS:
I could retune and only run E85 on the E55 as it isn't my daily, but I'm not sure if it would be worth it.
The amps/volts are definitely higher than stock. I'm just curious if there's a way to rewire the current setup so that it stops melting the relay.
SyHS (08-31-2019)
I personally would replace them. Replace them with something that has less draw. If you just fix the relay issue you may get wiring issues further down the line. Why are you running this much pump? What are your mods?
FBO makes around 530whp and 600ftlb. I have stock pumps but I'm thinking of getting a new socket and another relay and seeing if that will help. Maybe the socket itself needs to be replaced
