Colder Spark Plugs
Old Sep 20, 2019 | 07:16 AM
DQuickest's Avatar
2006 E55 AMG , 2005 Clk55 AMG , 2009 Range Rover Vogue
Colder Spark Plugs
Good Morning All . I am going to give the old girl a tune up this weekend . I bought a set of the Weistec Spark plugs . Yea , Yea . I know that was way too much money to spend on a set of spark plugs . Working 6 days a week and only having 1 day to enjoy tinkering with my car I
get a little excited sometimes and click happy on the LapTop . Lol . The Weistec guy told me that their spark plugs were 2 steps colder than stock . I know this is a dumb question but with a mildly modified engine will these plugs effect or cause any problems long term ?? Should I just wait and get a set of the NGK's ?? Thanks for your advice , Much appreciated .
Old Sep 20, 2019 | 11:56 PM
ta72's Avatar
2006 CLS55
I think 1 step colder would be better if its not too modified.
Old Sep 21, 2019 | 06:33 AM
DQuickest's Avatar
That's what I was thinking too . But I wanted to see some other opinions too . Thanks for the time Sir !
Old Sep 21, 2019 | 12:02 PM
SICAMG's Avatar
2005 e55 AMG
You always want to keep as much heat in the cylinder as possible....this is thermal energy. Running a colder plug will help with detonation as it will pull more heat out of the plug which is your hot spot so to speak in the cylinder. Better fuel is always the best way to go in the long run.
Be aware that that heat is also what keeps your plugs clean going through there cold/hot cycle.
Old Sep 21, 2019 | 02:42 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
If you plan to add boost mods, then go 1-2 colder but if just tuning up, then go with stock heat range. Cold plugs do carbon up easier and hwy mpg can drop with colder plugs. Mod-ing is fun, so give the old girl some power and a tune up.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 21, 2019 | 06:39 PM
tw2's Avatar
tw2
I wouldn't go colder unless you have some serious boost adding mods. Stock heat range should be fine with even 80-83mm pulley.
Old Sep 23, 2019 | 04:22 AM
PieRat's Avatar
CLS55
I suspect rough idle I get intermittently is from 1 step colder plugs even when modded!!
Old Sep 27, 2019 | 07:06 AM
DQuickest's Avatar
Hell yea brotha ! . Reason I was asking is that She already has some mods . I have a 77mm pulley ready to go . I needed a tune up badly so I went ahead and threw the 2 steps down in the car now so I didn't have to do them again in a couple of months . Thanks for taking the time to reply . Here's another one . Been checking out the long tube header situation . What do you recommend as far as i good product . So many choices . I was looking at the MBH's . Buy I didn't care for the way he's got the Cats accepting the O2 sensors with the extensions built into them like that .
Old Sep 27, 2019 | 07:07 AM
DQuickest's Avatar
I say drive like ya stole it . Let it eat .
