SC Pulley upgrade
Old Oct 17, 2019 | 12:25 PM
wpbmed's Avatar
E55AMG, Lexus ES350, Lexus LS460, AudiA6
SC Pulley upgrade
Has anyone gone to an 80mm or 77mm SC pulley and NOT done a tune or ECM flash? Can you bolt on the new pulley and drive without doing a tune? Thanks
Old Oct 17, 2019 | 03:49 PM
tw2's Avatar
tw2
The 80mm will run quite lean. I don't know if the 77mm will drive at all once you engage the supercharger. Why not just load a tune first?
Old Oct 17, 2019 | 04:38 PM
drothgeb's Avatar
Veteran: Navy
2005 E55
You can not spin the SC faster and not tune for it, unless you are looking for an excuse to replace the motor.
You can replace the pulley with a smaller one and drive if you are waiting for a tune. Do NOT go wide open throttle and it will be just fine (will run lean WOT). Like wise you can also drive with the SC pulley belt off without issue to be safe, and put it back on after you get your tune.
Old Oct 17, 2019 | 05:38 PM
wpbmed's Avatar
Thanks for the responses, seems to be the same sentiments when I did a search over the site.
thanks again.
Old Oct 17, 2019 | 06:31 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I have 83mm with Kleemann K2 tune that was suppose for 168mm crank pulley.
I have this set up for nearly 6 years.
Old Oct 18, 2019 | 09:53 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
We have the 77mm in stock.
Message me if you want to purchase one.
Thank you
Old Oct 18, 2019 | 11:43 AM
drothgeb's Avatar
Veteran: Navy
2005 E55
That's because the turns ratio is almost the exact same between what you have and what the tune is for. Your factory crank/83mm is 1.86 and the 168/90 (stock SC) would be 1.87, the OP question of an 80 or 77 is going from factory ratio of 1.59 to 1.93 or 2.0. Very, very different than your scenario.
