Fixed 80mm pulley...cooling?
Old Oct 19, 2019 | 08:20 PM
Rockfather's Avatar
2004 Mercedes Benz E55 AMG
Hello! Just need to know if I can run a fixed 80mm pulley without any additional cooling mods? If not what’s the best cheapest way to keep it cool and not f up the engine. Thanks!
2004 E55
-80MM fixed pulley
-RaceIQ tune
-Water wetter lol
Old Oct 19, 2019 | 09:43 PM
testknight's Avatar
CLS55
I don't think you'll like it without some cooling, IMO. I'd say get a heat exchanger and new pump and call it a day. Both are pretty cheap and easy to install yourself (or not too bad if you must pay someone). I'd just see you really enjoying it at times but feeling very limited when you get the inevitable heat soak. If you have the pulley on now, then I'm sure you've already got this feeling that your car isn't pulling as hard as you were expecting at times.
Old Oct 20, 2019 | 03:35 AM
hayseed's Avatar
04 e55
this looks to be a good option - price is right
https://mbworld.org/forums/w211-amg/...sale-lnib.html
Old Oct 20, 2019 | 10:02 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
All Fixed pulleys required additional cooling modifications. Id recommend at least Stage 2 cooling for an 80mm
Which is HE
Split cooling
Pump
Without split cooling water wetter is doing nothing for you.
https://www.vrpspeed.com/product/vrp-stage-2-cooling/
Old Oct 22, 2019 | 05:29 PM
GinDistiller's Avatar
2019 M5 Comp, 2005 Ariel Atom 2
Yep, and I'd guess w/ the palm trees in the pic you are in a warm climate. I needed a larger heat exchanger and new pump when I was running an 80mm FSP, and I'm in Seattle..
