E55 11.6 @ 119mph in Puerto Rico
MB E55 2004
Originally Posted by Cannis
maybe a stupid question, but is this a NOS shot into an intercooler? (I saw a post a bit ago from E55POWER about ordering a system that does NOS into the intercooler)
Also...what kind of system is this? Where did you install the tanks? Where is the NOS button and/or switch?
Also, what added safety do you need to run at a drag strip like this? Just a helmet?
tx.
sorry to sound like such a newb
-Cannis
tx.
-Cannis
I did install the intercooler chiller with no success this system is made for air to air, not water to air like the W211 E55's. I took it of and used the same line and tannk to go directly to the motor through the Y-connector of the intakes with a wet 55-32 combination.
Also, you need a helmet, jacket and gloves with NOS.
The System is a Nitrous Express, the bottle was installed in truck, were the spare tire should go.
Regards,
Manuel
MB E55 2004
Originally Posted by loeplaya18
Have you ever had a problem running the nitrous express on the E55....? I ran nitrous on my C32 and it was excelent.....just want ur 2 cents...
Regards,
Manuel
Volvo V90 CC
E55 power, congratulaton on having the guts (cojones) to put NOS in this car ! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I must agree with most people here about the trap speed being slow, I used to have an Impala SS (with 150 shot of NOS) and my best time was 12.6 @ 119 mph, then again my car had 3.42 gears, yours has 2.82 (or something like that), I also noticed that the car that ran next to you ran 12.3 @ 93 mph, so according to that your trap speed is good, but according to other tracks it is very slow.
Eitherway the time is great, once again felicidades ! !
#32
MB E55 2004
Manuel
#33
SL 65 AMG and E63s AMG
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
Do you happen to have a warming blanket for your tank? Also do how do moniter the pressure in the tank if it's in the trunk? I have found that my times are much better with a full tank with about 1000 psi than toward the bottom where volume changes make a big difference in the pressure.
I'm not familiar with using NOS in blown applications but in normally aspirated engines the maximum torque is obtained when the NOS button it pushed. My Vette makes about 700 lb/ft at 2000 rpm and goes down from there. This might account for the better low end performance and less effect on the high end.
#34
MB E55 2004
Regards,
Manuel
#35
Volvo V90 CC
Originally Posted by E55 POWER
I am currently not using a bottle warmer, since the bottle is were the spare tire would go it's pretty hot there, you have the two mufflers on each side. Also, we have the presure gauge on the bottle.
Regards,
Manuel
Regards,
Manuel
Do you have a window switch or when does the NOS come on?
#37
Manuel,
En hora buena!
Well done... 4mph is sort of low for a 100 wet shot, but it would have been interesting what your car would have run with and without the nitrous on that day, that way you could have gauged how much of an effect it had on your trap speeds.
119mph is nothing to sneeze at... realize that those kind of trap speeds are getting into Viper territory. With that kind of power you can pretty much roll on against just about anyone on the streets... pretty badass for a 4 door sedan.
On another note, I drove another one Monday... an '03 Tectite Gray one... it was almost mine![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
-m
En hora buena!
-m
#38
MB E55 2004
So, what kind of pressure does the bottle usually run at?
We are using a puch botton.
Regards,
Manuel
#39
MB E55 2004
Originally Posted by e55benz0
How did you launch, in what mode? That is a great time, congrats.
Regards,
Manuel
#40
................ Bell Helicopter & '05 C230 SS
Me avisas cuando vayas nuevamente a probar a Carolina.
PM me when you go, I'd like to see that. As a drag racer in my time, the most everyone used was either brute HP and low weight or we evolved later into small cars with weber side drafts, then turbos. Wow, it's been too long !!! Do you remember La Pista de Caguas ? Or maybe drag racing in from of the Tastee Freeze in Villa Blanca in Caguas ?
Carlos
Carlos
#41
1995 Ferrari Spider, Porsche 911 Turbo,01 Hayabusa, 01- E55
None yet, we moving up to a 150hp shot, I will keep you guys posted...
Almost as if it was revving so fast, the computer wasnt prepared for the shift.
Bouncing off the limiter on spray is very bad for the internals. I tried lifting right before the shift but it was hopeless.
After 3rd gear it was fine cuz it seems to have enough time to 'prepare' but 1-2-3 was BAD. After a few bottles of testing, the idea was abandoned.
Supercharger made much better idea. and no need to go home when the bottle goes dry ;-)
Hopefully the 211's computer is smarter!
#42
MB E55 2004
Carlos
Carlos
Regards,
Manuel
#43
MB E55 2004
Originally Posted by Autostream
I tried a 150hp shot on the 210 E55 and it didnt work because the transmission got confused all the time. Instead of shifting smooth at the redline like it normally does, it would hit the limiter HARD. bounce off it for a second-then figure out it was supposed to shift- and bang the next gear hard.
Regards,
Manuel
