Big throttle body. Reliable?
Old Jan 1, 2020 | 09:38 AM
lost27's Avatar
CLS55 AMG
Originally Posted by SICAMG
The 80mm with the shaft grind picked up exactly 1lb of boost for me, pulled much harder up top and I did have to do the throttle body adaptation stuff in order to get it to drive correctly recommended by Hulk. Took a couple times and a good drive cycle but for sure if it is driven exactly in the sweet spot with very light throtlle you will feel a little throttle close or hesitation but only I can tell and it has to be driven "right there" to notice Anyone else driving will never notice it.Then there are days when it is there 1 out of 10 times so it is no bother to me with drivability.
Did you ever get the P0106 code at cruise? My car was driving like a champ, massive drivability improvements, until I got that code yesterday but I didn't feel any noticeable hiccup.
Old Jan 1, 2020 | 01:21 PM
SICAMG's Avatar
2005 e55 AMG
No. No codes ever. You more than likely have some sort of vacuum issue some where and it is not the throttle body.
