3rd brake light, license plate lights and trunk malfunction
Old Nov 10, 2019 | 05:38 AM
Mario Vieira's Avatar
E200 Model 2007
E200 kompressor Avantgarde 2007 Model
Old Nov 10, 2019 | 08:45 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Check the harness at the trunk hinge point left side. Harness flexes every time trunk opens and closes and wires break.
Old Nov 12, 2019 | 04:39 AM
E200 Model 2007
Thank you
found the live wire broken off, repaired everything working 100%
Old Nov 12, 2019 | 04:43 AM
E200 Model 2007
Thank you
Checked harness at bootl lid and found wire broken off. Repaired everything working 100%
Old Nov 12, 2019 | 09:42 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
That is usually the culprit every time. As these cars age, the wires get stiff and inflexible. Which results in unfortunately broken wires.
Old Nov 12, 2019 | 07:53 PM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
Yep and unfortunately soldering the wires at the break will prove to be a temporary fix. A solder joint doesn’t flex like continuous wire.
Its better to replace the length of wire. Placing the solder joints away from articulation and avoiding fatigue from the hinge area.
