Door lock settings issue
First, when I use the key fob to lock the doors, it used to chirp to let me know that it was locked. Now, no noise at all. How do I get the chirp back?
Second, I rarely use the key fob to unlock the car when approaching it. I just squeeze the drivers door handle. Once the door lock actuated to open, ALL the doors used to unlock, and my wife could get in her side. Now, only the driver door unlocks, and I have to get in to unlock the other doors using the dash lock button. How do I return the car to the previous configuration?
Perhaps related, there now seems to be a micro second delay between the time I squeeze the door handle to the time the door unlocks, The whole system just seems kind of off. Any ideas?
Thanks.
Hold down the unlock and lock buttons together on the key for approx 6 seconds until the battery check lamp (on the key fob) flashes twice. This toggles the key between one door unlocking and all doors unlocking mode.
Or this:
Press the lock and unlock buttons on the key at the same time for 6 seconds. That will allow you to open just the drivers door with one press and all doors with 2 presses.
FWIW, mine is set for all doors unlock with one press or one pull of a door handle on the '05.
Your Shelby sounds sorta cool....
Thanks.
Hope this helps.
