Fuel tank issues?
Old Dec 24, 2019 | 08:40 PM
AMG__POWER's Avatar
2024 c300 , 2006 E55, 2005 e320, 2007 gl450, 2025 glc300, 2025 e450
Fuel tank issues?
Hey guys, so about 2 years ago I replaced my fuel tank under MB extended warranty for this issue, now today I was driving and after I filled $30 in gas and got a half tank the gauge went to 0 and had a - - - in the range indicator. Now I’m reading this is the fuel level sender which seems costly at around 500 dollars + labor and I’m wondering if this is still covered by Benz Bc there unit is new
can anyone please help this car is becoming a chore
Old Dec 25, 2019 | 01:39 AM
dblock110's Avatar
C32 AMG
it's a 15 year extended warranty from date of purchase or build date . I was a month out and after fighting with MB they wouldnt cover it. needed sender and fuel pump spent $1k and then labor. I am talking to NHTSA to try to get this thing into recall status.
Old Dec 25, 2019 | 04:23 AM
AMG__POWER's Avatar
man that sucks, I had my system changed 2 years ago. This fuel sender issue is just now happening so I’m expecting them to take action on their own faulty parts.
Old Dec 25, 2019 | 10:25 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Two separate circuits so it would be unusual for both circuits to fail simultaneously in the fuel tank. Check the connector on the fuel sending unit on the driver's side to ensure it is seated correctly and that none of the wires are pinched and shorted to ground or broken. You can also pull the connector and take resistance readings directly off the pins on the top of the cap. Floats are located on both the filter/regulator and the fuel pumps.
Looking at the five-pin connector on top of the filter/regulator on the driver's side, assume pin 1 is closest to the car's centerline and pin five is closest to the passenger door; pin 1 would be common ground, pin 3 is for the float on the passenger-side fuel pumps, pin 4 is for the float on the driver's side filter/regulator.
Photo shows the internal connector for the floats; the only way I can see for a simultaneous failure is for that connector to fall off which would be very unlikely. I think the issue is outside the fuel tank. EDIT: Failure of the ground wire connection common wire to rear SAM (pin 1) would result in a simultaneous failure. Schematic attached. You'll need to verify continuity from the filter/regulator connector to the rear SAM connector 2, pins 4,5, and 6. Fuel level sensors are B4/1 and B4/2.
Old Dec 25, 2019 | 12:02 PM
AMG__POWER's Avatar
wow thanks for the write up bro! I pray your right and it’s just a wire issue
Old Dec 25, 2019 | 04:05 PM
Fountain35's Avatar
He's a fantastic asset for us here, I appreciate all his feedback.
Old Dec 25, 2019 | 04:49 PM
AMG__POWER's Avatar
I cousins agree more, and funny enough today started the car and the gauge works again? Starting to think it’s the rear Sam maybe
Old Dec 29, 2019 | 11:55 AM
Pmarino's Avatar
04 E55 AMG BLK/BLK(MyDD), 06 CLK 500 (wife's) 07 ML500, 2012 C300(son's)
Check for water intrusion
Old Jun 3, 2020 | 03:38 AM
Feuerdrachen's Avatar
CLS55
How can we all help support you in that endeavor? It's BS that a lot of '03 and '04 MY owners are left out for this glaring safety issue.
