Fuel pump ??????
Old Dec 26, 2019 | 08:09 PM
user 5580820382's Avatar
E55
Fuel pump ??????
Hey guys need help with trying to find the issue. I think I fuel pump. Just came back from 900 mile trip car sat for 1 hr and now just cranks no start. I checked relay its good, checked fuel rail got no fuel coming out and no pressure. I just had the fuel.recall done last year with new tank and pumps
Old Dec 26, 2019 | 08:15 PM
Bankroll's Avatar
E55 AMG
Take it in, and have it diagnosed.
Old Dec 26, 2019 | 09:32 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Did you check the correct relay? AMG harness is different from non-AMG harness. Search and ye shall find...
Old Dec 26, 2019 | 10:36 PM
E55
I checked at drivers side in trunk bottom right last one at bottom
Old Dec 27, 2019 | 10:15 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
That's for the non-AMG car. AMGs use a different wiring harness.
The 2003 through 2005 has one fuel pump relay on the passenger side behind the panel (no access port so you have to pull the whole panel). 2006 has two fuel pump relays on the passenger side trunk.
Here's some info on the differences between the two versions:
https://mbworld.org/forums/e-class-w...ml#post6585628
Read the links in this post (entire threads because some info does not come out until the last few posts):
https://mbworld.org/forums/w211-amg/...ml#post7933111
If the tank warranty work was performed and the dealer failed to install the fuel pump adapter cable, you may have a valid claim against them.
Old Dec 27, 2019 | 11:39 AM
E55
Thanks guys I check and the warranty work was performed last year
Old Dec 27, 2019 | 05:50 PM
E55
Found a burnt relay going to change the relay make side and female side
Old Dec 27, 2019 | 05:59 PM
E55
Does anyone have the part number for the relay socket connector or just use a universal one
Old Dec 27, 2019 | 08:41 PM
E55
Hey guys are both relays 40amp cause I found a 20amp and a 40amp
Old Dec 27, 2019 | 11:40 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Fuel 40 amp. I assume air pump relay is 40 amp but they never seem to burn out. Part numbers are out there. Advanced search on my username and keywords such as fuel pump relay or fuel pumps.
