TCC Lockup Issue - Resolution?
The zero timing thing isn't normal, it sounds like it's detecting detonation. Is there a misfire counter on the E55?
This is the first time I'd thought to check timing, and Tony at RaceIQ agrees, just got logging software and am sending to him once I have some good logs. I've never had a misfire code and the engine is very smooth (although down on power in this instance), so I'm a bit stumped. IATs good, intercooler pump good, new o2 sensors and MAP last year etc etc.
More to come..
More to come..
I mean, I'll be happy if I find a solution, but will shed tears if these are the culprits...
"Yes, it turned out to be a TCU issue despite no codes, ended up with a tuned TCU from MKUltra and it was flawless after that (and much more enjoyable to drive)." MKUltra being Tj.
Here's the graph that I'm sure some of you are familiar with, I can see w/ driving that my TCC doesn't go to 'OPEN' until I'm almost at a dead stop. Computer shows 'SLIPPING' all the time once the car gets moving. Verified that at 1000 rpm of trans output speed and my foot off the gas completely, TCU still shows 'SLIPPING' when it should be open, and you can feel it unlock as the car is almost at a stop. I'm wondering if something is just buggered in the torque converter and causing all sorts of odd pressure.
I know mine's an '03 and it did have the Valeo radiator, however I changed it out when I got it and had my fluid tested - completely clear of glycol. That's not to say a previous owner could have had that and did a flush at some point.
Maybe time for a high stall? With how well she drove turning off TCC w/ Star, I'd assume it would be another jump like that to go to the UPD unit, traction be damned.
Did you fix this issue?
I highly recommend the MK Ultra TCUs though, best upgrade I ever did on the E55.
I've changed the Torque Converter to a low mileage used one and put a new TCC Solenoid in, but car still drives the same.
I suspected valve body leakage but when I disable lockup with star it drives perfectly so I don't think that's it.
Maybe I get a used TCM to check if it fixes that.
Mine is a 2007 e220 diesel, I envy your previous 55 amg.
