Did HSTC helped my 60’
Old 02-21-2020 | 02:19 AM
MSG 55G's Avatar
Veteran: Army
2006 E55
Finally took my build to the track after updating TC with UPD 3000 HSTC and a fresh dyno tune. Got my PB time slip with 11.4, 1.5 60’ but, trap speed is still sucking 115mph.
In November, I ran a 11.6, 1.6 60’, 115mph without the updated mods but with 68 fsp.
I’m very happy with shaving off 0.2 and a nice 60 footer, it’s the trap speed that frustrates me. Gonna change out the original SC tensioner and send pulley out to griptec hoping it’s just belt slip.
The HSTC felt amazing on launch, like a rocket from low to mid ends but top end just felt weak like car was on 5th gear over drive.
have following mods: 72mm FSP, 82mm TB, LTH, x pipe no cats, 550 cc injectors, BWK, upgrade superflo ic pump, dyno tune by HD Tuning, split cooling, 5 gallons trunk tank with Rule 2000, KnN filters, 3000 High stall torque converter, C63 mufflers, & Killer Chiller with Drag Kit. DR: 16” CLK Wheels with MT et street rear and spare skinnies fronts with MT.
At Fontana Speedway
PB but 115mph???
Dash Command data at end of run.
IAT stayed below 120
November slip without HSTC or dyno tune.
Old 02-21-2020 | 07:25 AM
hayseed's Avatar
04 e55
I am not a racer but what gear were you in and what rpm were you at across the line? ,,, consider 2:82 or 3:06 diff gears to move the shift points/revs ? and faster shifts --- just a thought during morning coffee
MSG 55G (02-21-2020)
Old 02-21-2020 | 11:13 AM
tlambert's Avatar
2005 E55 AMG
Add the gas and run in the 10s??? Lol.
Your times sound pretty damn good! Your car sounds like my set up. I have a canned tune, 185 lower pulley stock upper. Stock mufflers along with the other mods you listed. Mine did a 1.58 60ft. 10.39 @134 but it was being sprayed.
I don’t have the KC or TC.
Old 02-21-2020 | 11:43 AM
kiluminati616's Avatar
2004 E55 AMG / 2019 Audi Q7 / 1991 300TE
Nice et but something is going on up top... Which is weird considering your IAT stayed so low. My bone stock e55 ran a full second slower but same trap
MSG 55G (02-24-2020)
Old 02-21-2020 | 12:54 PM
E55Greasemonkey's Avatar
This place is a joke.
Your trap is at least 5mph low, indicating you are making torque but not HP. What were your dyno numbers? I never heard of your tuner. Could the problem be in the tune? What is your intake/air filter setup?
Old 02-21-2020 | 02:49 PM
MSG 55G's Avatar
Veteran: Army
2006 E55
thanks G! I’ve ran three different tuners (RaceIQ, DTK, and now dyno tune) and trap speed all the same. HD Tuning is a local tuner here in So Cal, very popular with AMGs owners here. He got my rwhp to 515 and 583 lbs of torque. Gained 75hp at 4k rpm and 50hp at 4.5k compared to base pull with DTK Tune.
i have stock intake with KnN filters, they’re about ten years old filter.
Dyno tune
Base pull with DTK Tune
Old 02-21-2020 | 02:54 PM
MSG 55G's Avatar
Veteran: Army
2006 E55
thanks T! So frustrated with trap time, I’m thinking belt slip. Didn’t see boost over 12 psi. Car have 189k miles, work horse!
last result would spray too! Hahaha
Old 02-21-2020 | 02:57 PM
Maybe time for a compression check- I just nervously did mine @ 153k but all was good
@ 178psi +- on all 8 cylinders. Last time out ran 11.6 @ 121mph in 60F weather, but 160F IAT's at the end of the track. 153k miles it's a road warrior!
Old 02-21-2020 | 03:00 PM
99lightning's Avatar
99 ford lightning
log load and boost. Your car since it is coming out good, and making that kind of power should prob be north of 125mph traps.
Old 02-21-2020 | 03:16 PM
His MPH is already low at the 1/8th mile IIRC compared to my runs
Old 02-21-2020 | 04:28 PM
99 ford lightning
and low to my stock pulley mph as well so something is going on there.
Old 02-21-2020 | 09:41 PM
trabots's Avatar
2006 E55, 2006 SL55, 2006 LS7 Ute
Forget the et, your trap speed sucks for such a good 60 foot time which gave you a reasonable et. I have basically the same mods but have 125mph through the traps with a 2.0 sec 60foot.and 11.4 sec et. I would be in the 10's with a 1,5 sec 60 foot.
Old 02-23-2020 | 09:15 PM
PieRat's Avatar
CLS55
Lo
Could try log timing maybe its pulling because your getting knock up top? With those nice iats it should be nice and high with only 3.5 pulled after 95f iirc.
Hows the transmission do you think the torque converter is giving up? Did you replace the solenoids, conductor plate and inspect the pump (known to fail time to time) when installing the 3k stall?
Old 02-23-2020 | 09:27 PM
E42AMG???'s Avatar
E420
I was having the same issues. Let the car sit for a few hours when you get to the track and only move it when you have to. Regardless of iat I would run 5 mph slower when car was thoroughly warmed up. You have belt slip, I have very similar setup and on the street I would see 18 psi up top with 68mm but at track only 14.
With the high stall doing a burnout and the quick rev up in 1st it roasts the belt and it doesn’t grip right after. Switching to a fixed pulley with clutch delete to see if that helps.
Old 02-23-2020 | 11:44 PM
Fantomas's Avatar
2006 ML350, 2005 C55, 2004 E55
You can tell your belt is slipping from your base pull with DTK tune, torque dips at 3500 and goes back up at higher RPM as the belt begins to grip more. Your IATs gain is too low, if the car was making the right boost you should see a 30-40 degree rise even with a killer chiller during the 1/4 mile run. Then your dash command logs, assuming they were at full throttle at the end of the run you're only making 1 psi more than stock, you're supposed to see about 15.5psi with a 72mm pulley.
Old 02-24-2020 | 02:39 AM
MSG 55G's Avatar
Veteran: Army
2006 E55
Can’t say how much I appreciate all your inputs! I’m really hoping it’s just belt slip and nothing major.
As mentioned, I’ve ran RaceIQ, DTK, & the recent dyno tune and all three got the same results of trap speed of 115-118; a common denominator. I mostly run on S mode with ESP off.
Will be swapping SC tensioner assembly and sending pulley to griptec, is there any other remedy to prevent belt slip? Both belts been changed two weeks ago.
I plan on swapping to a 68mm fixed pulley and getting a dyno retune. Would my tuner be able to tell if belt is slipping?
Old 02-24-2020 | 02:42 AM
MSG 55G's Avatar
Veteran: Army
2006 E55
E42AMG, what belt size you using with 68 pulley?
Old 02-24-2020 | 03:00 AM
MSG 55G's Avatar
Veteran: Army
2006 E55
PieRat! I just changed the C plate only, after the high stall was installed back in December, had issues with speed sensors prior. I’m not getting issue with tranny since plate was changed.
my tuner supposedly bypassed the first stage of timing pull at 95. Is that a good thing?
Old 02-24-2020 | 03:02 AM
MSG 55G's Avatar
Veteran: Army
2006 E55
99lightning, How do you launch with your HSTC?
Old 02-24-2020 | 04:42 AM
99 ford lightning
very carefully lately i just bring it up between 1800 or 2000rpm and roll into it before flooring it. that will get me into the 1.6 range. Most of the time my car will short shift the 1-2 shift in the 4500 to 5500 rpm range why i do not know.
Old 02-24-2020 | 07:36 AM
SICAMG's Avatar
2005 e55 AMG
99 You can't manual shift and override the early shift ?
Old 02-24-2020 | 08:39 AM
99 ford lightning
it comes up so fast alot of times i bounced it off the rev limiter. its a fluke thing with my car maybe changing a conductor plate and a valve body would help.
Old 02-24-2020 | 12:15 PM
E42AMG???'s Avatar
E420
515 was the smallest I could get on. Now I have larger pulley for the bwk and phenolic spacers, so 540.
Old 02-24-2020 | 08:40 PM
Fantomas's Avatar
If you're slipping with a 72mm you will slip worse with a 68mm. Are you running a Gates RPM belt?
Tuner should be able to tell the belt is slipping by monitoring boost, if you're not seeing ~15psi with 72mm pulley you're slipping or have a boost leak.
Old 02-25-2020 | 12:02 AM
MSG 55G's Avatar
Veteran: Army
2006 E55
i just mashed it at the line with DR it dead hooks. Are you running DR?
Quick Reply: Did HSTC helped my 60’
