Boost gauge on meth injection throttlebody spacer
Old Mar 9, 2020 | 09:42 AM
Rpkxnoscope's Avatar
CLS55 AMG 06
I want to know if this Throttlebody meth injection spacer would allow me to connect a boost gauge to my m113k, so I can read my psi coming from the supercharger. https://www.vrpspeed.com/product/vrpmethplate-2/ Here is the link to the plate. Otherwise i'm still trying to figure out a good place I could insert a boost gauge to read the psi, I figured this plate could possibly give me slightly better air temps as well as the ability to read the psi as well as have the option to install an actual meth kit in the future.
Old Mar 9, 2020 | 10:19 AM
E55Greasemonkey's Avatar
This place is a joke.
No, that will only read vacuum it is before the supercharger. You can remove then drill and tap one of the intake manifolds and use a brass barb fitting for the pressure hose. Meth/water is a waste of money on the E55.
Old Mar 9, 2020 | 10:33 AM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
If you have a obd reader/scanner which are cheap, you can get your boost number electronically using a number of apps via the stock MAP sensor
