E63 Front Air suspension - Arnott or Bilstein
#101
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I know a fellow who operates an inde shop and he has a Chevy shop van with 300+k still on the original OEM ball joints. He was the one who directed me to AC Delco.
#102
Now that we talk balljoints. Do I need to deflate the strut to remove lower balljoints or is it enough to release the control arm from the strut and subframe?
#103
I'll probably jinx myself, but still on the original bags from 2004. I should probably order a set of bags from RockAuto for the shelf as their price is less than half of what it is in Germany. Also, I highly recommend AC Delco ball joints for the 211 from RockAuto (Upper PN 45D0155 Lower PN45D2437). More expensive than OEM's, but far better quality. You can expect 150+k miles or more. My OEM's needed replacement at around 65k miles.
#104
if it’s made in turkey or anywhere in europe it’s usually good. proforged is good taiwan stuff if they make something for these cars
#105
These units are ISO/TS 16949 certified and not made in China. As I previously posted, they are very high quality.
#106
![](https://mbworld.org/forums/images/ranks/veteran_marine_corp.png)
I have always used Lemforder, so I can't comment on AC Delco, but I'm sure that they made good components.
#107
I don't know if I ended up with a DOA unit, but the replacement front driver's side strut (Arnott) failed after 3 months. Thankfully it was replaced under warranty from Rock Auto.
#108
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
When I did my upper control arms and wheel bearings I realized that the right front strut is an Arnott reman and the left front is OEM. Thanks, whichever previous owner did that.
#109
#110
I disagree, the reason why we replace them in pairs, is so they both have the same life expectancy. Meaning they should now wear at the same rate, as compared to one new and one old component.
#112
That's an idiotic statement. If you have a failure, it's one thing. If you're replacing them because of mileage that's something else entirely. Bottom line is that they do not have to be replaced in pairs in the front ... unless you want to for some other reason.
#113
My way, when you replace them together, they both have zero wear.
#114
You made a statement that they were supposed to be replaced in pairs because one is Arnott and the other is OEM. I'm telling you that's a myth, or a lie, and it isn't necessary or required as long as the Arnott version is ADS.
If you want to replace them together as a maintenence repair because of age/mileage, that's a different argument.
It's not *** backward in any way. Your comment to replace them in pairs so both have zero wear is completely ****ing stupid. If one failed at 30k miles, I wouldn't replace both. CLS notoriously fail passenger front struts that are OEM, rebuilt or new from Mercedes. It's a defect in their replacement parts because it's not coming from Germany (likely Mexico). You don't have to replace the driver side just because the passenger air spring rubbed internally, and blows.
#115
It makes no difference to me what brand they are. I'm only saying that they should be replaced in pairs because and age/mileage.
Last year, I had my drivers side front air strut blow on my E63, it would have been idiotic of me to replace just only the blown front strut.
When I know, its just a matter of time before the other lets go, due to its age/mileage. That is my thought process.
#116
Lets stop the insults and agree that we both have different ways of going about this. You have yours and I have mind. And call it a day.
#117
I've put hundreds of thousands of miles on Lemforder ball joints/thrust arms/suspension components in general on both BMW and Mercedes. They're German made. You can't do any better, and they're what came with the cars. No surprises.
#118
#120
SPONSOR
2007 Mercedes E63 AMG
if one strut is quite a few years or miles difference it is recommended to replace them in pairs. shocks do not have the same dampening or rebound curve even new so pairing a new single strut with an old strut can cause this difference between ramps to be even more drastic.
you wouldn't replaced a tire as a single unless it was within the same timespan of the other new tires. same reasoning here.
#121
SPONSOR
one thing I did screw up was...with Arnotts their ADS capable units are tested and rebuilt OEM units of unknown mileage. I wish now when I purchased my Arnotts that I ask my send in's were tested and rebuilt as they were only a few short years old. my driver's side front blew a hole in the bag. this process does take a lot longer though.
#122
#123
When I rebuilt my whole front end, it was only upon removal that I realized I had one Arnott and one OEM Bilstein! So I DID take them to an RMT in Pompano Beach, Fl. and they gave me credit for the Bilstein but Not the Arnott as they explained the internals were not the same (Arnotts don’t have the Adjustable Dampening Feature of Airmatic). I originally had dropped my Intake Manifold off and had RMT rebuild that and they did such a great job, I entrusted them to rebuild the AirSprings. That was back in 2018, however recently, I rebuild my whole rear end and I brought them both Rear AirSprings and when I went to install them, one of them was disfigured(ie-when I filled it with air, it bent like a banana) so I returned and they fixed it within a few days. A couple weeks later when after that same marathon Rear End Build, my radiator blew, so while I was up front, I had the bumper off and also did a Headlight Lense Cover Replacement, I noticed a leak under my driver side AirSpring and took it off and brought it back to RMT yet again. This time they explained that if its leaking like that, there’s nothing they can do to “repair” it. In other words, once You ever see it leaking, the AirSpring Oil Seals are toast and those are not Servicable apparently. I thought therefore there would be no warranty so I asked if they had another one I could purchase. The guy kindly corrected my misunderstanding by clarifying they they would replace it with another since they knew firsthand how much work I was doing and therefore had not put many miles on the car (less than 2 k since I had originally brought them 8n back in 2018). I guess it helped that I was a return customer but I was very impressed and now my car rides like a dream! Kudos to RMT in Pompano Beach!
