2003 e55 p0451 code
Old Apr 5, 2020 | 11:02 PM
npappasan's Avatar
2003 e55 AMG
2003 e55 p0451 code
So my 03 e55 was previously doing the dang red check gas cap warning with CEL. It was throwing out a p0455 large EVAP leak code. Got a new gas cap with no luck. Changed the purge valve solenoid under the hood with no luck. Then worked my way back to the charcoal canister. I could intermittently smell gas at the right rear wheelwell. The canister looked intact. Took out the canister vent solenoid and the O ring was pretty shot. I replaced with new canister solenoid and O ring and that seemed to work. No warning or CEL for almost a month!
Until today....
Red gas cap warning and CEL came on today. Now the code is a p0451, which seems to indicate a faulty fuel pressure sensor.
Can’t seem to get any straight info on this sensor online. Where is it???? Please somebody help!
Old Apr 6, 2020 | 04:17 PM
npappasan's Avatar
2003 e55 AMG
Bump
Old Apr 7, 2020 | 10:48 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Fuel pressure sensor is located on top of the fuel filter under the driver's side rear seat. It's part of the fuel filter assembly so hope it's just a bad connection and not a bad sensor.
Old Apr 7, 2020 | 11:05 AM
npappasan's Avatar
2003 e55 AMG
Thanks. But it looks like the sensor can be bought as a stand alone separate part. I was getting the same vibe as what you’re saying but why would it be sold as part that looks like it would unclip from the bracket it is in?
Old Apr 7, 2020 | 11:07 AM
npappasan's Avatar
2003 e55 AMG
Old Apr 7, 2020 | 11:09 AM
npappasan's Avatar
2003 e55 AMG
It looks like a plain old sensor. Mounting clips. Electrical connector. Etc.
i guess I’ll just have to remove seat and look at it.
Old Apr 7, 2020 | 11:11 AM
npappasan's Avatar
2003 e55 AMG
Doesnt make sense that it would be available as a part if it were a fixed component of another part.
Old Apr 8, 2020 | 10:50 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Go for it and let us know. Would be a good DIY.
Old Apr 8, 2020 | 11:15 AM
npappasan's Avatar
2003 e55 AMG
Well, I’ll look at it first and see how the sensor is connected/attached and go from there. Not really any solid info on this out there.
Old Oct 19, 2020 | 09:25 PM
Ivan-2019's Avatar
2004 E500 4matic
Any update on this one? Getting the exact same problem on my 2004 E500. Replaced the charcoal canister, shut off switch, purge valve, gas cap and getting the red fuel cap warning after about 30 to 60 minutes of driving.
Old Oct 19, 2020 | 09:32 PM
npappasan's Avatar
2003 e55 AMG
Cleared code after I originally posted this and light hasn’t come on since.
Old Oct 19, 2020 | 09:34 PM
npappasan's Avatar
2003 e55 AMG
Check under hood at back of driver side intake. That vacuum/EVAP hose is notorious for wiggling off.
Thats what mine turned out to be after replacing everything also like you have.
