Coolant drain plug location
While you can drain the radiator from the petcock located on the driver's side, bottom corner of the radiator, you run the risk of stripping out the garbage plastic threads Valeo/Behr uses for it.
I usually drain mine from the intercooler pump connection. You can save it from there also if you aren't planning on flushing it.
Thank you al. I found it. I tried to follow the "how to" section for E class but the color and shape they have mentioned are nothing like what I found, that why I had trouble to locate mine. The drainage plug on my vehicle is black and has a handle that you can open it by hand. Just turn counter clockwise 45 degree and pull it out. Yes, it's on driver side, on the bottom, on the side,
Im looking at instructions on how to change my coolant. What seems odd to me is that Im supposed to drain the fluid then add water and drain again. The idea being that the water is supposed to mix with the residual old coolant so it can be removed. Then you drain again and fill it up with 50/50. But there will still be residual wont there? And now that residual will be half old coolant and half water, so 75% water. That seems wrong. I can add 50/50 to fill it but the residual at 75% water seems like it would throw off the 50/50 balance. It seems it'd be better to just drain and refill with 50/50 and skip the water step altogether. Any thoughts?
Just add back in two gallons of anti-freeze FIRST, then fill with water until it's full and you're more than fine. For 50/50 mix all you need is 1.75 bottles of Mercedes coolant. Remember to use distilled water for perfect pH.
You're not supposed to mix anti-freeze types, so that would require a complete purge. I just paid $20/gallon for the Mercedes concentrate, so paying $26 for two gallons is actually more expensive than my $1.00 of distilled water ($21.00).
FunkTron (05-05-2020)
Mercedes Blue Coolant = BMW Blue = Volvo Blue. They're all G48, just buy the cheapest
It leaks badly not too long after I changed my coolant. I think I broke the valve you have mentioned. The tech said I need new radiator. I don't see any leak looking from the top or both side of the radiator. it could be that valve or some thing else from the bottom, didn't get a chance to craw underneath the car yet. Just wish it was a hose or something Lesson learned the hard way.
I would also look up high on that side with a UV light for a crack in the tank. That tends to be the side where an older radiator tank would make a 1/4" miniature crack, and run down to the bottom from there.
If you fear damaging your radiator or petcock, then take it to a shop and let them purge and fill it. I do this every two years, they use a machine that extracts all the old coolant, then sucks new coolant into the system, thereby removing any air pockets in the entire system. Then we run the car for a few minutes and top off the coolant as needed. Bam.....
Cost <$140 no fears or tears 🤔
2006 CLS55 AMG, 2005 SLK 350 AMG
If the radiator uses the very common drain 000 500 01 85 and it happens to break you do not have to replace the radiator. They are readily available from online MB dealers and on eBay at about $7 https://www.ebay.com/itm/Radiator-Dr...AAAOSwuxFYuJQS
dustinN (08-08-2020)
On the CLS55 (or E55) you can just bleed it through the actual bleeder line at the top of the engine (rubber plug, put a hose on it leading back to the reservoir and get out 99% of the air from both sides of the system (low temperature circuit and engine circuit) while the system is filling. As soon as you run the car, it will continuously bleed out the air until nothings left. Use a clear hose if you're new to this type of work, and you'll see solid fluid instead of air bubbles.
The vacuum system also doesn't pull out all of the coolant from both systems, which is why I never bothered with it on the Mercedes. The same way the oil suction won't pull a quart out of the front portion of the engine pan, so any lazy arsehole who tells you otherwise is leaving a quart of dirty oil in your car. Have to let it out from the drain plugs, which I would do anyway over "suction" from the top.
Yuille36 (08-02-2020)
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I am having a dealer flush my brakes and considered adding a coolant change to the list. I did some poking around the forum and I see no need for the vacuum apparatus that is specified in WIS. Should be totally DIY-able. Plus, a forum member reported a heater valve O-ring failed when vacuum was applied to the system. No need for any of that...
I’ve never bought into the hype, of using suction to extract oil from the pan. I always preferred draining the pan, and oil cooler as this method leaves very little residual oil inside the engine.
Update ... I had to replace the whole radiator. The tech estimated 2 hrs for the job but it actually took him 4.5 hrs to get it done. I'm glad I didn't try to do it myself :-)
