19’ two piece amg rims hardware question
E63 AMG 2009 E55 AMG 2005 E63 AMG Wagon 2007
I wanted to get my rims refinished but I’m worried about the bolts being sealed. Or even if they may snap if I try loosing them. Anyone have any experience with taking these rims apart or even where to find extra bolts incase mine snap off during refinishing?
Then I would try to locate a manufacturer that makes three piece wheels, hopefully the bolts they use will be the same as the ones you need.
This should help you. It is a Titanium bolt, a M7x1.0 pitch thread with a triple box socket head. Search that info and you should be able to find them. I don't know what torque to set them to, but be careful, the titanium is brittle and I've heard of others snapping them. See link below, you should be able to find them here in America if you look around. the specs are half the battle. Good luck.
https://allforwheels.com/m7x24-TITAN
Its a "triple square" socket, not box. Individually, they aren't cheap. BBS ones may be better quality. I've seen them on alibaba in bulk for much less, however it may be cheaper lower quality.
