Are 722.6 gearboxes interchangeable?
Old Sep 16, 2020 | 02:29 AM
e500slr's Avatar
2011 E63, 2013 CLS63
Hey guys,
Wondering if anyone knows if you need to replace a 722.6 transmission with the exact same numbers after the 6 ie. 722.6xx or are they interchangeable?
Old Sep 16, 2020 | 05:31 AM
cm60k's Avatar
You can put TT gearbox # (722.649) from:-
04-06 "C215 CL600/CL65" or "W220 S600/S65" or 07-13 "W221 S600/S65" or even 04-11 "R230 SL600/SL65/SL65 BS",
it's really great, with (900Nm)..
-;-ZAYED-;-
Old Sep 16, 2020 | 09:19 AM
coupesedan's Avatar
CLS55
Didn’t all of the SOHC engines change bolt pattern in 05 or something?
Old Sep 23, 2020 | 12:35 PM
e500slr's Avatar
Wondering if a 722632 will fit on a car with a 722.618?
It's from an S430 going into an E320 so it's going from a more power car to a less powerful...
So technically it should handle it, the question is, will it run and operate ok electronically?
Old Sep 24, 2020 | 08:36 PM
ta72's Avatar
2006 CLS55
-;-ZAYED-;-
Are those trans straight "PLUG & PLAY" to the M113k cars?
Old Sep 25, 2020 | 08:05 AM
cm60k's Avatar
Yes, it will be PLG & PLY,,
my friend put it on his 05 E55 last year, so coooool..
-;-ZAYED-;-
Old Sep 26, 2020 | 02:13 AM
ta72's Avatar
2006 CLS55
-;-ZAYED-;-
So what is the difference from the 722.643 vs the V12 trans? Hows the shifting difference and so forth?
Old Sep 26, 2020 | 03:35 AM
cm60k's Avatar
Shifting & kickdown is little bit faster, but firmer than stock, especially with 2>>3.
-;-ZAYED-;-
