Random misfire E63 AMG
and the winner was... the intake manifold had a huge crack on the throttle plate. Luckily, RMT is local to me so I had them rebuild the whole intake manifold. Came out looking awesome!
no more hiccups on restart or misfires - also, the idle now is a smooth as butter.
Only thing I wish they didn't do was paint it, it looks fine, but the grey is slightly off from the stock grey and visually mine was mint. Good bang for the buck though if you don't want to open it up, and especially if you have any physical defects.
I just had to take mine apart mysel as I had a throttle body go out.
Was really odd, the inside was totally mint, both TB's had zero wear or oil on the plates, looked brand new.
The front TB did have aluminum oxidation on it, swapped out w a super low mileage CL63 TB slapped it together and code's gone.
The IM is actually really easy to work with, just have to take your time and take pictures to make sure you put it all back together.
I too wanted to OEM paint, but the light blast and respray they do slows down the corrosion. Prefer to have a deterrent to the corrosion over the looks.
